RB20, std turbo, no engine work. oil filter relocation kit (no leaks, greddy) oil catch can (doesnt look to be leaking, also greddy)
had my car in for its regular service (also had a radiator flush) and on the drive home i noticed some white smoke coming out from bonnet. Checked defi, water temp was fine, oil pressure looked fine, not lots of smoke, but enough for me to pull over to check it out. When i opened the bonnet what little smoke was there dissapated and no source was obvious. so i just continued driving home, watching temps and pressures the whole way. no more smoke appeared
checked coolant and oil levels, both ok, oil is a little high, might be because of extra capacity of relocation kit though ?
then tonight while driving along, under load i noticed a strange noise coming from the engine bay, seemed pretty close to me in the cab, sort of centrally located and sounded right behind the firewall. popped bonnet to have a listen, gave it a bit of throttle. the noise seemed to be coming from the rear of the block, i think from the head.
from inside the car the noise sounded like a sort of gargling bubbling noise, like air being sucked though a water line or something (but increases with engine load), hard to describe.
before the service i have started to notice some white smoke out exhaust on boost, thinking turbo oil seal, mechanic rekons so too. maybe im wrong and its the head ? would this explain the noise :S
kinda worried, gunna call my mechanic first thing in morning lol
any info for now would be great though
https://www.sau.com.au/forums/topic/274496-wierd-noise-after-service-s/
From what I understand, theres usually more coolant in the block than there is in the lines + radiator combined. I would scrutinize how the exactly the flush was done.
thanks for the input, ill ask about it when i call, as i mentioned though, coolant levels were fine and water temp was ok (78 degrees) so hmmm :s confusing lol
If it was done properly, should have drained the coolant out the head by the cylinder block drain plug (I assume it's in the same place as the rb26, a real pig of a location with the rb26 at least).
Is your coolant milky brown?
Bear in mind these 2 pictures are from the R32 GTR service manual, procedures should be the same for the rb20 i would guess.
smoke at the back of the block could possibly be from a leaking rocker cover gasket. or simply a bit of oil was spilt when they filled it up. that should just burn off after a little while.
noise could possibly be air in the water line from the turbo to the block, or the heater hose (did you have the heater on at the time?
rocker cover gasket was replaced when i did my 100thoughsand k service, was leaking a bit before that, all good now, my mechanic rekons just a bit of air in the water system, has dissapeared today and water levels and temps still remaind fine, oh well, gone i guess haha, cheers for the input guys :(
im not a spectacular mechanic but in the last 4yrs ive been one apprentice lol... ive seen quite a few cars come in with complaints of the same noise... ur mechanic probably didnt have the heater on when he was bleeding the system. if ur competent wen it comes to playing under the bonnet let the car completely cool turn the key on and turn the heater on turn it right up i should say 30degree watever i dont remember and if u wanna be double sure that all the air is gone shouldnt have to but yeh jack the car up slightly at the front or park on a slight incline if u have one so the radiator is higher then the motor crack the bleeder and keep pouring in water until all the air has stopped flowing out the bleeder replace bleeder then take the cap off and start the car let it get to full operating temp it will push out a lil bit of water dont stress and then wen the thermostat opens it will pull in watever water u have left may even push out a lil bit of air from sumwhere aswell then fill the radiator to the top and replace the cap.... if ur noise still persist u may have to push water into the heater core but thats a different story lol
    • Thanks mate 👍 The car was brought into the UK by a USAF mechanic until he was stationed back to the US, one owner later I bought her back in 2009. Luckily the only corrosion was on the sill seams, so once taken back to metal and treated and sealed all ok, I then undersealed the car myself and check yearly and treat any corrosion which to be honest is zero. She's garaged most of the time and hardly ever driven in the rain, but as you say most are rotten unfortunately, I was lucky in finding her as she was and still is in excellent condition.
    • Stunning car.  Looks amazing!  You're in the UK?  How the hell do you stop your car rotting away beneath you?  British cars are the WORST I've ever seen in regards to rust.  Some of the cars SR Autobody have done are borderbeyond saving.
    • not a date code? or a foundry code?
    • I have up to date pics of the engine build and turbo conversion over on my instagram @skpro_jects if you want to take a deeper look.   Basically the exhaust manifold is straight bolt on and the ports match (they arent any smaller than a 25 or 26 head).    the intake ports are different shape so the 20/25det manifold will bolt up but wont match properly or seal. You will need to port match using the 25det gasket as a stencil. Personally i ran the entire stock 20neo intake setup and have configured the swirl valves and torque valve to work based on my custom parameters to help with off boost response and spool. But this is using a standalone aem v2 ecu. The stock 20det ecu wont be able to control them.
    • Hi. a little later but if the topic is here. So...the exhaust is the same and you can use 25/Turbo or any aftermarket? What about intake side? Is it too "plug n play" or? (i do not remember for 100% but i think that one intake to head gasket was little bit different than on the RB25 - i bought gasket kit way back) I know that even if it "plug" those butterfly swirls would cause ECU to be confused or?   Just asking for the info 🙂 and of course the RB25 things are easier to come by
