Hey Guys, have got a few things for sale, will keep adding to the list as i find more stuff
All this stuff to suit RB26DETT, all brand new
ARP Main Studs $225 inc Freight
ARP rod Bolts $75 inc freight
ACL Race Series Main bearings Std Size $110 inc Freight
ACL race series Conrod bearings Std Size $55 inc freight
R33 GTR Crank, brand new $900 plus Freight
All this stuff still in boxes
More stuff
RB26DETT Block with main girdle/cradle: Has been hot tank cleaned, bored out to 87mm, decked a fraction to tidy up the face of the block. has had the mains girdle/cradle fitted and checked the tunnels for out of round/out of spec(Needs welch plugs fitted). $1000 plus freight
Venolia 87mm forged pistons to suit RB26DETT, Brand new in box, with Nissan Genuine rings ready for fitting. All ciclips/gudgen pins etc there as well. $1100 inc freight
STD AFMx3 $20 each
R32 GTR Crank Angle Sensor $50
6x Coil packs $70
ABS Module $120
R32 GTR Steering Rack with tie rod ends $150
R32 GTR Clutch slave Cylinder $40
Clutch Master Cylinder $50
Brake Booster and Slave cylinder $150
A/C condensor $50
STD R32 GTR BOV $130
A/C Fan(Fan that sits in front of condensor that also switches on when engine gets too hot) $50
R32 GTR Bonnet Catch $80
Front wheel speed sensors $50 each
Rear Seat(No rips, bit dirty and faded though) $50
Passenger Seat(No Rips) $150
LH Door(White and complete) $250
Bare steering column $40
Glovebox Lid $10
Tailights(White Surrounds) $60 each or $100 pair
STD Fuel Pump $100
Drivers Side Headlight $100
Front propellor shaft $50
Starter Motor $50
Another 6 coil packs $70
Coil pack resistor $40
Rear window $50
Quarter windows $60 each or $100 pair
Front Crossmember $100
Tailshaft $80
ALL PRICES ARE EXCLUDING FREIGHT
Michael for questions 0438911374
Thanks
https://www.sau.com.au/forums/topic/274508-rb26-and-r32-gtr-stuff-for-sale/
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
    • Nvm ignore this I read it wrong
