Cheers for all the info there Henros, i know i'll be giving it a go!
easier than replacing the bulbs all the time!!!
question about setp 8, is that plugging straight into the original socket from the wedge globe? no mods needed here?
cheers again
Craved, the whole thing will plug straight in, no modes required.
Hippy, they are just normal 1/2 Watt metal film resistors, more than adequate as the power dissipation is less than 1/5 W. I'm not quite sure about the second part of your question. Do you mean the socket sitting under the PCB? That's the original socket for the parker bulb.
Bah...
I applaud your effort, but you can just buy these bulbs (with an LED matrix) from Raybrig or other bulb companies right off the shelf and plug it straight in.
No PCBs, No soldering, no measuring.
Autobarn should be able to hook you up, if not, try PD's Car Audio in Hornsby... They had heaps last time I checked.
Hippy, all white LEDs have a blueish tinge because they are essentially blue LEDs with an internal phosporous coating. The amount of blue various from manufacturer to manufacturer. You can get blue LEDs with different shades of blue. Jaycar for example, sell 470 nm blue and 505 nm blue/green LEDs.
Steve, the extra diode is there to provide reverse polarity and trasient high voltage protection, the IN4004 has a reverse breakdown voltage of 400V. LEDs have much lower reverse breakdown voltage. In reality tho, you could do without it, but you need to increase the value of the resistor as the diode helps to drop around 0.7V which now has to be shed by the resistor.
Merli, construction was half the fun, for me anyway. :D
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
