E.o.i Nasho Cruise
Marsss
 Share
FYI... there are road works currently happening in the National Park... Only a short area at the moment... maybe 500 metres? But no doubt they will be doing more in coming weeks...
So maybe a different location would be best for now?
Then again, not exactly sure if this thread is still about a Natio cruise or somewhere else from all the conflicting posts! :P
  • Replies 53
Still doing a Psych. Report for one of the bikies' defence barristers. Might have it out of the way by then. Hope so.
Oo fair enough, good luck with that Tez
hmm 26th, Gemma's organising one on the 25th :( natio run
anyway... 26th it is... Thanx to mods for looking after the thread....good to know you guys are there[/sarcasm]
Starting time will be 11.30 am... meet up outside Just Jap.
No idiots please..
No idiots please..
report a post and ask for help if you need it mars.
s'all good sammeh.. i figured there would be mods roaming these here threads just in case... i'll know next time :D
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
