2006 BF MKII XR6 Turbo (First Rego'ed April 2007, Warranty until April 2010)
6 Speed ZF
~54,024km (Bought in November 2008 with 20,101km, I have personally put 34,000k's on it out of which 30,000 or so is highway driving)
272rwkw, tuned by Unigroup Engineering
Rego until August 18 2009
Exterior Mods
18" 5 Spoke Rims
Headlight Protectors
Bonnet Protectors
Wind Deflectors
Debadged
Window Tinting
Colour Coded front grille
Phillips +80 white globes
Interior Mods
X-Force Gagues (Water Temp, Oil Pressure, Boost)
RCA Pre-out Modified Headunit (Standard)
Jaycar 6.5" Splits with MBQuart Crossovers
A Pillar Grilles
4x100 Jaycar Digital Amp
iPod Auxillary Input
2 x Clic-on Mounts (www.holdmyphone.com.au) - Will include TomTom GO 730 for $400 extra (6mths wty remaining)
iPhone 3G Mount / Aux Input ($100 extra)
XR Floor Mats
Mechanical / Performance
DBA4000 Kangaroo Paw Rotors
Bendix Ultimate Pads
80% Kumho tyres all round
F6 Cold Air Intake
xCal 2 Flasher included, Tuned by Unigroup Engineering (Valet/95/98 Tunes)
Siemens Deka Injectors - Not fitted but included with sale
Centre Muffler Removed
Serviced every 5-7500km, Royal Purple Oil
New Diff Bushes/Swaybar Links
Reason for sale
The car used to be my daily commuter from Gosford to Chatswood (outside of peak hour)... 90% of the K's are highway K's, I've recently moved to Ryde, and really, this is overkill machinery for a 15 minute drive, and I really don't get the enjoyment out of it that it deserves. Car will be fully detailed prior to sale
Seeking $22,500 o.n.o, with full logbooks.. Have bought another car, this will just be sitting gathering dust. Realistically make me an offer and we can go from there :(
CONTACT
0431 10 10 16
[email protected] - MSN/Email
New Photos as of today.
However this evening on the way home a truck has lost a load and clipped the side of the car (scratches on front qtr panel and front bar), will be getting this all fixed up and cleaned so it'll be nice and shiny for the new owner!
Vehicle Enquiry Results
Registration Number: BB38AG Request Id: 107721726
Registration State: NSW Date: 12.06.2009
VIN/Chassis: 6FPAAAJGSW6G54751 Time: 16:25
Engine Number: JGSW6G54751
* ENCUMBRANCE/WARNING DETAILS *
The vehicle indentifiers you have supplied indicate that the vehicle has
been recorded as a Repairable Write-Off. The vehicle may have been repaired,
inspected and re-registered.
Before you buy the vehicle, contact the manufacturer to check if the
the manufacturer's warranty is still valid.
There is no financial interest
VEHICLE DETAILS MATCHED WITH RTA
https://www.sau.com.au/forums/topic/274555-2006-bf-mkii-xr6-turbo/
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
