A friend of mine told me that at about 3000 kms his R35 started "clicking" loudly from the wheels on hard cornering. Well, on que, at almost exactly 3000 kms mine has started doing the exact same thing - and I havent even driven the car that hard. Sounds break-related. Does anyone else have this problem, or a remedy?
It sounds like the ball joints under pressure are you turning at full lock when this clicking sound happens. :(
Duncan, thanks for the link, it looks like they have it sussed out and are awaiting a fix for it. Also looks like a lot of GTRs have the problem. I'll take the info you sent me to Crawfords.
Cheers.
I had exactly the same noise when turning right at higher speeds, a couple of runs through Galston Gorge revealed this. The strange thing though is that the noise is now gone, I do not know what has changed.
On a side note just for readers information, there is a rattle noise from the front of the car when I go over a bump, this combined with with clicking when turning raised some flags. Anyhow after some inspections I found the issue for the rattle when going over the bumps, the top steel pin that goes through the caliper is a floating pin and vibrates and rattles.
I am curious who else has seen this.
Cheers
Edited by Gibbo_R35
Cheers
Thanks Gibbo, interestingly the noise has not reappeared today on my car either. I havent had the rattle noise.
  • 7 months later...
I've had this clicking noise surface recently.
It seems the USA boys thinks it is one of these:
1. Missing top pad retaining SPRING (the front calipers usually only have one of these)
2. Rattling pad retaining PIN (as mentioned above)
3. Loose tie rod ends
Did you guys resolve this and/or had it resurface?
I'll add another one to this. I had the problem appear at around 9000 kms and took it in to Nissan. They said they spoke to Japan and diagnosed it as the fully floating rotor making noise because some anti-seize grease they use between it and the hub had washed out. Anyway they replaced it with a non genuine compound as they didn't have the proper stuff in stock and it lasted a week before the noise reappeared. I'm now on 17,000 kms and about to take it back in as I want that looked at as well as my MFD backlight dying on hot days as well as my interior mirror developing a droop on 40+ days after a day in the sun. I'll see if I have that retaining clip installed tonight and suggest that to them as well the tie rod end when I drop it off this week.
No top pin anti rattle spring found and that upper pin clicks loudly with a similar sound when I push it side to side. To me it seems the obvious fault/problem. See what Nissan thinks...
Out of interest i put the car up on stands today, and started t up, put it in gear, bit of throttle, turned full lock (left) and no clicking. So when there is no load on the wheels/suspension i dont get the clicking. Might be a clue... anyway i am going to be taking a closer look over the next few days, just ran out of time today.
I'm no R35 mechanic (just a normal mechanic anyway :down: ) but a click on full lock is normally worn out CV joints. Has anyone actually got to the bottom of this problem yet?
Yes I can see how you would think that, that was my first suspicion as well but the Nissan Tech had a listen and said it definitely didn't sound like CVs. Plus a fiddle with the brakes and it gets better immediately, albeit temporarily in my case. In fact last night by just playing with the pins and moving them back and forth stopped the problem for about the first 20 mins of this morning's drive before they must've shifted again to their favourite rattling position! The sound from the pin when manually rattled does sound a lot like the click you hear whilst driving and the US guys seem to be convinced that the anti rattle spring omission seems to be the problem..
i havent read all the posts or the links, but ive had cars with similar issues (NOT R35) and with these cars its either a Faulty brake assembly (uneven ware on one pad), CV joints or a worn/broken wheel bearing..... ive eevn had a car with diff probs making a similar sound but for the rear of the car, and even the power steering...
Like i was saying i was getting the clicking, just turning left. Put the car up on stands and with no load on the wheel, and with wheel turning...no ticking. Anyway i had to replace the pads anyway... So i did remove the pad pins and re-install again. Also the tie rod end nut was not very tight, i could tighten a couple of turns. After i did all this and put it all back together the noise was gone! So unfortunately i can't isolate where the noise was coming from exactly. It's either the tie rod or something related to the caliper. It doesnt look like a stuffed CV. Interestingly also, i noticed the tie rod end cotter pin can rattle around, when you move it with your finger it sounds a hell of a lot like the noise in question.... tick tick tick... so i tapped it down tighter. Anyway the noise is totally gone for now i will let you know if it comes back. Relieved it's not a CV.
Edited by LSX-438
Was informed by Main North Nissan today that they have three owners with the clicking problem at the moment and are narrowing down the cause on a test mule. So they told me to hold off bringing in mine till they sort it out. I told them about the info available on the US forums regarding missing top anti rattle springs and loose tie rod ends and it appeared to be news to them! We'll see if they can come up with a permanent fix soon.
we get a lot of nissans with similar noises. found that the cv shaft spline is dry causing the clickling. i removed cv, lubed spline and retorque the hub nut properly and noise goes away...
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
