I'm chasing a decent Auto Electrician, I want to get my taillights on my R34 hooked up so that all four lights get brighter when depressed instead of just the outer two.
Anybody you would trust your car with that doesn't break the budget? (Preferably in or around Osborne Park as that is where I work)
https://www.sau.com.au/forums/topic/274563-good-auto-electrician/
Lachlan, DIY mate! I know my way around a Skyline, Nick's an electrition, and everyone else would be happy to give you a hand. We could easily do this is an arvo.
Otherwise my mates always looking for cashies. Might be a bit expensive though.
Edited by NA_Goodness
Had to get some wiring done in my brake lights anyway and went to Autospark in Osborne Park. Nice guys and they helped me out and did me a reasonable price. Got him to look at hooking up the taillights and said it COULD be done but it would be quite costly (I believe having the indicator in the light is a bit of a problem). SO spending more then a few hundred on my taillights just doesn't seem worth it when my car needs so much more.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
