Hey Guys,
Just have a sub and some rims + tires for sale, I need to buy a bed and subs and wheels are not very comfortable to sleep on ;)
The sub is a home unit - 12" Isobaric 350WRMS, basically 2 carbon fibre subs one in front of the other in a big box. I built it a few years ago and it cost about $1400 at the time. It could do with a bit of paint tho, but it still pumps pretty hard if you want it to, I went a bit over the top so I wouldnt need to thrash it. It has not had much use for the last two years, but its hooked up at the moment so you can have a listen - bring your own music to give it a test :thumbsup: Its a pretty big unit and takes two people to lift it! Chasing about $500
Skid rims- stock r32 rims with some goodyear rubber, there is a bit of tread left on them but two of them have some camber wear on the outside, plus there is a spare tire. After about $180
Located in hobart, prices negotiable - I dont have a mobile, so shoot me a pm and I will give you a call, thanks
https://www.sau.com.au/forums/topic/274631-fs-sub-skid-rims/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
