Hey guys,
Feeling the need for a change. I have decided to sell/swap my 1967 300SEL Mercedes Benz. It is an awesome classic car which must have been unbelievable in its day. It has a RB30 High comp Turbo motor in it with a Jatco 4spd. I am looking to swap it for an R34 or even sell it.
PRICE: $20 000
Details:
Engine: RB30 High comp. Turbocharged.
Gt35R copy(from Japan)
FMIC
Custom made full Carbon Fibre intake plenum, Carbon fibre intake trumpets
Rebuilt head, new springs, Wade 818 cam (1000ks old)
GTR 440cc injectors
Microtech Lt8s
Gearbox: Jatco 4spd Auto
Stage 1 shift kitted
(5000k old)
Suspension: Original self-leveling airbag suspension.
Engine driven air pump
High or std setting from inside the car
This is all original suspension (1967!!) The ride height is also fully adjustable by removing the height control sensor arms and shortening or lengthening them. It takes about 5 mins to change your base setting. The height adjustment from inside could be handy if I ever got pulled over too! (not that I ever have)
Interior: All original, with the exception of no glove box( because there is a nice little Microtech sitting behind the glovebox lid instead!!) And the dash is fitted with blue led lights, with the original clock converted to a boost gauge!!
Bodywork: Original paint. Bonnet is crazy cracked all the rest is pretty good. Small rust spots on lower doors and rear window. Small dent in rhf guard and small dent in drivers door.
Wheels: 18 inch Dolce DC-12.
Exhaust: 3 inch straight through 2 2inch Carbon mufflers.
Car made 250Hp @wheels on 10psi, 350ft/lb torque. Tuned by Dyson Rotary.
Let me know what you think, even if you have something of interest to swap plus cash would be good too, trying to save for holiday!
https://www.sau.com.au/forums/topic/274642-for-swap-300-sel-benz-for-r34/
Forgot to mention it has a Pioneer stereo. Head unit, pair of 6x9's, and two 12inch subs in the boot with amp.
where are you located mate, i got a r34 imlooking at trading off atm.
  • 1 month later...
    • Believe it or not, it's about right, remember it's also the 4AT which is worth a good bit too. This sounds along just right with everything else ever posted here on a stock turbo at reasonable boost.
    • Ok, thanks, legends. I'm hoping I don't need to pull out the window regulator. I was thinking when the window is out, the regulator mechanism shouldn't interfere with the corner piece and then be able to be removed through the speaker hole. Fit the new corner piece and then refit the window, and Bob will still be our uncle.
    • Sounds spot on. My R33 gtst with a bit of boost made 162
    • So quick update.  got my Nistune done from CMS and was a smooth drive back.    Shane at CMS is good with his work and car runs fine. Was worried my fuel pressure might be cooked as my fuel leaks on a full tank 😂 but apparently she held pressure.    I asked him to install the boost controller so I don’t mess anything up, and he was happy to do it. Old solenoid is still in there but capped off.  I will remove that from the bracket next weekend.    for now…. I am happy with my 168 KW 😂😂  All she got is the 3” turbo back exhaust and the BC
    • If the tyres were fitted when new, I wouldn't expect much over 5 years of use. Especially if the car lives outside full time.  If the tyres had been stored under ideal conditions and are being purchased new, I'd fit a set of already 5 year old tyres if I only expected to get 1 to 2 years of use out of them.  I've purchased many a set of new (but quite old) tyres from St George Tyres when I just needed some decent rear tyres to drift on.  Here is a pretty crazy example, can't say I've ever bought 11 year old tyres from them before though lol.  https://www.stgeorgetyres.com.au/momo-tyres-245-45-17-outrun-m3-official-product-by-momo-italy.html
