ITEM 1: 12 inch sub in box, 8ZED ultimate electronics (ebay jobby) condition is perfect had it in car for about a week, 400w rms, 800w max, MODEL # gr-12w its yellow $70 http://8zed.com/products/auto-subwoofers-speakers/
ITEM 2: sony XPLOD 1600w single channel amp few scratches works awesome comes with wires paid 200 second hand sell $150 MODEL # xm-d1000ps
ITEM 3: sony XPLOD 6 inch splits brand new in box http://www.sony.com.au/product/xs-gtx1620 sell for $100
ITEM 4 kingwood 6x9's brand new in box never used peak max power 500w MODEL # gs-a6927 $20
$300 the lot or swap for good head unit
NO PICS, 0408055849 or pm
https://www.sau.com.au/forums/topic/274651-stereo-stuff/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
