  • Replies 86
Put me down as a yes Cara.
Is there time time to dial in a bit more boost on the dyno? Or will it be strictly get your sheet and gtfo?
if there are any special requests let me know and im will dicuss with John Keen
Well I was interested, till I saw it was only 2WD - Boo to you Cara :banana:
there is an AWD class, even tho its a 2WD dyno.......................
I have spoken to John about having AWD cars there and he is happy to accomodate for them, by dropping the shaft
IF IT HELPS GUYS TROPHIES AND PRIZES UP FOR GRABS TOO!!!!!!!!! :thumbsup::)
i gotta book betsy to be tuned by keeny soon as ive put the new turbo on...i'll be definately keen....lets try and get more numbers than the one i did at classic performance last year!!!
excuse me. but my 34 is called betsy.
copy cat!!!!!!!!! :thumbsup:
will there be pos pulsar category. cant have u pitting me up against sr20 pulsars :thumbsup:
if i remember correctly the PGA dyno days have a "little battler" award for the car with the least amount of power output
last time some exa won it i think
so dan your in the running for that mate
how long have you had your betsy for????
3 years , 28th sept this year :thumbsup:
There is no dropping of shafts on the subaru Cara - won't be there sorry (well not to compete/partake anyway)
hmmm bugger that seriously sucks!!!!!!!!
will be good too see you there tho!!!!
^^ winner winner chiken dinner
guess that will come in handy for you krishy while im winning max hp in my n13 :P
Edited by Inline 6
Guest
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
