Double figures for the Honda :D but only just
I think you should James, we can organise a competition, $10 per guess of what power (kw) it makes at the fronts. The correct guess, or closest guess, wins all the cash, minus James' entry fee!
  • Replies 86
Im keen, should have a few things sorted by then, or i could always bring the Honda for a laugh ! :)
James, bring the honda and I will bring the wagon and we can go for the lowest power. lol
work ute ftw lol
LOL this is the craze at the moment isnt it....Dan mate i think you have a battle on your hands for the "little battler" type award :cool:
I will be more then happy to put my line on the rollers....its still running el stocko turbo so should be interesting to see the result of the last dyno day to what it is making now....hoping that its still making same power lol...but the winter weather is always good for dynos
im now a maybe. got another fine today, and ill probably be heading to perth for a spell in a couple months, so cash is gonna be tight for a while..
So a Drag meet is a 2 day event for you then Dan
1 to get there and 1 to get across the line bahahaha :)
still faster than cara :)
still faster than cara :blink:
well guess that means way faster than you ;) less your al bundy pushing has 10rpushkw
stop encouraging her to dump more $ on that car
n kye talking of attending an event :P
Edited by Inline 6
Hey everyone
i just wanna get a rough idea on who would be interested in being a participant for the SAU:SA Dyno Day, to be held in August,
Thanks heaps
Cara
im currently organising flyer with Damo at the moment, which will be posted up once done. all will be revelaed then, should be in the next week or so.
Guest
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
