18/06/09 Baskin's Meet With A Twist Of Car Detailing!
  • Replies 294
which baskins Robins is this guys wouldn't mind checking other R34s on the meet
cheers
if there are THREE 34s there... i may well have to bring a change of pants... :bunny:
pfft 34s,
32 is where the legend began
they are faaar superior!
:P
...ok
unless its a 34 GTR Nur :laugh:
astro could never afford a Ztuned.. unless he cupped some major kahuna's at the casino!
ive done crazier shit for cash...
34s are teh secks!
can't wait to see this black one!!
gtfo newb!
:angry:
34s are teh secks!
Wooooooooooo
Yeah blacks a sick colour, ive changed my mind about the suss colours i was thinking about respraying mine (yes thats right Taz u were right). Think ill go for something with a bit more depth like a black.
Edited by Danski
pretty sure i also said that light blue wasn't the best colour choice :angry:
BRANDON! - post up that pic u sent me of the black 35GTR
its jizz-tastic
gtfo newb!
:angry:
I'll gtf your o in a minute boy :)
it's just simple fact - black silver and dark blue 34s are sex incarnate.
some colors just work well on certain shapes
33s - black and white
32s - gunmetal
35s - white and silver
simple facts bitch :D
I'll gtf your o in a minute boy :angry:
32s - gunmetal
simple facts bitch :)
ok ok deal (only cuz u said gunmetal 32s are the sex)
maybes move these epic chats to our other thread? lol
Yesh Madam.
http://www.gtrblog.com/2008/06/12/singapor...ts-matte-black/
http://852racing.com/Images/blog_03122009_...e_r35_gtr_1.jpg
http://images.google.com/imgres?imgurl=htt...sa%3DN%26um%3D1
(the orange 33 looks like something that came out from Tokyo Drift...)
But like I told you on msn, theres no words to describe seeing that in real life.
I think this has been posted somewhere in the r35 GTR thread some time ago.
Edited by Brandon
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
