Hey guys,
I've recently built a r32 GTS25 with s2 25DET.
I am planning on a 5 stud conversion,
having hard time deciding whether to go for the R32 M-Spec setup or the R33 25t setup.
As far as I know if I go for the R32 option I wouldn't need to replace the master cylinder/brake booster?
If so is there anything additional I'll need to do if I go for the R33 25t option?
The reason for that is that R33 seems to have a bigger caliper and at the moment I am pumping out around 200-250kw without a proper tune. but ultimate goal would be 400kw+.
https://www.sau.com.au/forums/topic/274739-r32-r33-25t-5stud-conversion/
Hey guys,
Very similar piston sizes, same pad dimensions, so the same master cylinder will work for either.
Cheers
Gary
