I'm thinking of getting a white on black background personalised plate for my white 33 gtr but I dont know if the slimline or the standard will look better on the car. Anyone have any recommendation? Or should I go standard on the back and slimline on the front? Cheers
Brandon
https://www.sau.com.au/forums/topic/274770-personalised-number-plate/
Going off this website I assume the slimline ones are called 'prestige'? If so, seems pretty similar to the front plate on premium plates in NSW, if that's the case I reckon it would look great on your car.
I've got slimmer plates on the front of my car and I'd say it wouldn't hinder the airflow to the intercooler as much as a standard plate would (even if the difference is only marginal). I just put some longer bolts and spacers between the bumper and the plate so that I didn't have to bend the number plate...
Ive got the same plates but black on white. They're definatly good looking and make a car stand out;
Maybe you could get "GTR 24U" :P
Had to be quick to snap up those plates eh mate? Good effort!
I think that cos they're both only 5 characters they also just fit the JDM lic plate holder nice and snug right?
Have had them for a while now actually :P
Yeah your thinking is correct, they both fit the rears perfectly, no need for trimming at all
slim line make a big difference imo, well worth it, finding a good combination is harder unless u go prestige. I got Blue on silver, slim front, standard back.
Looks like a perfect fit! What are series is that though? I've got different side indicators comparing to yours. Why is that??
Series 1 or 1.5 (1995) , (series 2 motor), modded front bar though, I removed the middle section (where the plate is now)and filled the cutouts,
Edited by hardcorz
Yours is a GTR isn't it Brandon? the front bumper/spoiler, front indicators and side indicators are all completely different to a non-GTR (GTS / GTS-t)
Yea it is. Just that I've never noticed that difference until someone offered me the side indicators for free only to find out they're totally different.
But yea, I'm settling for white on black. Placed the order yesterday. I've also took the carbon blade off for sanding and getting it recoated. The previous bastard who did it just recoated the faded coat without sanding it down... looks like crap and got some massive clear that's cracking from probably birdshit. 1/3 done!!! big job to just sand the bugger down (you'll see white powder when you start and yellow when you're through the top top and finally CARBON!).
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
