good to see dedication.............as far as im concerned. unless i get an email directly from sony or polyphony telling me more details i'll ignore the other hype, where ever it is writen..ill wait, and play other games in the mean time. A
s for buying an Xbox........forza 3 is the ONLY reason i would even contemplate that as it is a dam good game. but 1 game aint gonna get me to buy an xbox. thats why i have a PC.
Bozodos is sounding like the door to door bible bashers trying to sell you Jesus although it clearly saiys athiest on the door.do you scan the site looking for pages that say PS3 just so you can tell us to buy an Xbox? (most peeps do own both)
Edited by boiracer
If the full game resembles the prologue i have to say that the wait will not be worth it.
Having played prologue non stop since it came out, then play Forza 3, Polyphony has to come up with something spectacular.
And i fear that GT5 just wont cut the mustard. I mean 5 years of development?
In theory Prologue should look and and feel like GT2 compared to the new game with the amount of time spent on it.
Someone dropped the ball somewhere, and no amount of fine tuning of the game will pull them out of the shit, and they know it. They are just delaying the inevitable walk away from the series :huh:
I fear you may be right Dave :D
nah boiracer, just saying that there's a viable alternative for racing sim lovers already released.
Arrogant wanker devs who keep their games as vapourware long past announced release dates like this deserve to lose public support, like 3DRealms.
I'm starting to get excited bout this coming out. A few more months is fine, as long as they get the game spot on.
Downloaded GT Academy this morning. Must say i love the sound of the gearbox whine on the tuned car. Might need a new TV with 1080 to make the most of the game though.
For me personally. The number 1 concern I have is what they do with the Modification system in the game. After prologue Ive been worried they would swap the system over to that lame power up by 20%, weight down by 10% rubbish. This would really put me off the game bigtime. Im hoping they use a GT4 type system but much more comprehensive where you buy individual parts of different levels. Then they move the power band around suitably, even effects like clutch slip if your power exceeds your other mods just like reality would make for an awesome feature. 1 thing I'd keep from prologue is keeping a decent group of races using a points system (albeit with the much nicer mod system) to keep certain races as close as possible. (Yes sometimes you don't want to race a 600kw GTR against stocko Hybrids :P
Sadly my idea of a mod system with clutch slip, brake fade and overheating are probably just a dream. Maybe in 30 years time with Gran Turismo 7 or 8 at the rate they are going.
Luke
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
