:P ty its actually measured off my R33 interior.
well. it only took a few arvos to weld up. could use some refineing and was relatively cheap.....the only catch is the seat. I had it lying around and its an actual car recliner, so it weighs as much as the rest of it combined. a generic seat of a lighter cheaper description would make it much more affordable.
Edited by boiracer
dude.. srsly??
what do you think polyphony have been doing for the last 5 years??
my money is that you'll forget all about forza before long..
working on other games.. As they stated in their interview.. Prologue and PSP GT and a couple of others.. You didnt think they been spending the last 5 years only working on this game?
well there is a light at the end of the tunnel. the game is currently in production.
there was some funny responses to this on GTPlanet. this was my favourite.
FOX NEWS BANNER APPEARS
This just in, a truck carrying all the Gran Turismo 5 discs has been loaded onto a plane to Yemen, along with a printer, a man wearing baggy underwear, and a guy wearing a shoe with a match.
yeah i been waiting for them to put a r33 gts-t in it too. do they have the r32 gts-t in the earlier ones? from memory they do. sif put that gutless piece of aids in and not the 33
I'm not sure. I haven't played GT since GT2, have been playing Forza.
In Forza 3 I had to convert a R33 GTR to RWD to make it like a GTST but it still keeps the RB26 so it's not a real GTST of course.
in gt4 you could get an r32 gts-t m spec, though if i remember you could only get the r33 gts and not the gts-t.
i will be pretty sad if theres no r33 gts-t. but you would think after taking 20 light years to make they would have all the nissan skyline's down pat. same goes for the 180sx.
Anyone know for sure if the R33 GTST is back in or not?
I'm tired of pulling out GT2 and the OLD Playstaion to relive my old car :)
I suppose we'll find out in about a months time.
pft, your doing it like a sucker
forza 3 has all the cars....
pretty sure one of the guys at harvey norman here has one. needless to say he works in the computer section. and he drives a supra, which isn't suprising since a hell of a lot of IT nerds drive imports. pretty much never see one in a commodore. it's usually either lancers or imports.
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
    • I'm a bit stuck with this one fellas, I recently decided to undertake a turbo conversion on my GTS-4, ended up pulling the motor to replace all the seals and do an mls head gasket and arp head studs while I was at it. Everything has gone according to plan, no oil or coolant leaks, compression checked out, and decided to give it a test before I book it in for a tune As it stands right now, the turbo only has oil lines plumbed so that I don't put boost into my untuned engine, and I'm using the factory GTS-T crossover pipe with a maf and poddy as a temporary intake. The car starts with relative ease and idles amazingly, however as the title suggests it really doesn't want to rev up, runs very smooth but almost feels choked out and unresponsive to the throttle, almost like it's running lean or something? I've triple checked my vacuum lines and timing with a timing light, injectors haven't been touched as of yet to avoid flooding the engine and worked perfectly beforehand, new plugs and coilpacks, I've even unbolted the cat just to see if it spontaneously collapsed, no dice The car currently has a nistune r32 gtst ecu installed so I have no way to check for fault codes. At this point I'm a bit stumped. Is this normal behaviour for a car with a turbo bolted onto the exhaust going nowhere? I'd imagine the turbo wouldn't cause this much restriction in the exhaust without the boost going through the intake. Any ideas? If necessary I can link a video of how it responds to full throttle while in neutral.
    • Insert tab A into slot B?
    • Instructions seem simple enough to understand.....
