Shops that sell it early run the risk of being fined. thats's why very few do it. used to be done much more in the past, but these days you get people showing off like above posting pics of the game with the reciept, which usually has the store details which gives sony all the info they need.
Gona pick it up 12:01 from 24 hour kmart tonight. I think its been really overhyped and our expectations have been raised way too high. Hope im wrong though.
This guy seems pretty depressed playing it lol. http://au.gamespot.com/shows/now-playing/?...rismo_520101122
Edited by S4LVA
agreed, i think my expectations are to high and after watching that bit of gameplay i think i might be a a bit depressed lol, but we will wait and see.
Damn 20 mins. Was hoping i'd be able to play it before getting some sleep for work lol. Yeah I skipped through the video and it just looked like any racing game. He hit another car and it didnt spin out or even skid it just swayed a tiny bit and kept driving normally. At least now my expectations are way down so when I play it itll seem good :P
lol 20mins is a lie! it has been going for 40mins now!
now its on 4seconds which was more like 2-3mins lol
im not going to cry if its not everything i expect. the interiors and other premium cars will come. im just happy its coming out.......although i cant pick mine up till saturday!!!
and aslong as it drives well with the G27 ill be happy. gotta be better than driving the same cars around the same 4 tracks in prologue like we have been.
installing now :P so how long did install take u guys?
fucking forever!
indicated 20 minutes = nearly 2 hours
indicated 18 minutes = over an hour
indicated 12 minutes = an hour
indicated 1 minute 10 seconds = 45 minutes
indicated 8 seconds = 15 minutes
i was pulling my freaking hair out. now its finally done. fuck this im going to bed
Edited by jonboy
wow. mine is the original 60gb console. maybe the new ones are faster.
also has anyone seen anywhere local that you can buy the HKS racing controller? i found This Page but i think thats from the states. i asked at ebgames last night and the guy had never heard of it. i also heard its not wireless.. i might cry if thats true
    • FD RX7 I would probably marry if legal R32 GTR is toughest NSX looks like it's made from leftover Prelude and Accord bits
    • When going to a suspension shop should I send them the default nissan settings or just let them do their own thing? I ask this because I have aftermarket rear camber arms (front end is basically stock after I change to those nismo bushes)
    • Ok sounds good, thanks for your help. Hopefully if I end up changing it to the nismo bushes I don't get that veering issue. I don't think there's a point in lubing up these bushes again. Weird that it it makes just as much noise with all the grease inside it versus without grease prior to removal. Bizarre.
    • Yeah, you don't need camber bushes on stock arms to make a car drive straight unless it's got another problem. F'rigsample, slide the thing into a kerb, bend the front subframe mounts a little....subframe is now twisted, shifted or otherwise in the wrong spot...and you need to do funky stuff with the wheel alignment to get it to drive straight. Maybe a little more caster on one side, or a little more camber. FWIW, I can have my camber off side to side by a half a degree or more, and either way, so more one side, or more on the other, and the car doesn't really want to pull to one side. It will definitely ride road camber differently, and want to track uphill (ie, towards the centreline when on the LHS of a normal crowned piece of road, like it should) or want to roll downhill (which it really shouldn't). But on fairly flat road surfaces, like the middle of a 3 or 4 lane motorway, a half a degree either way doesn't make a lot of difference. I sometimes do quite a few miles with my wheel alignment messed up, because I don't always get a chance to set it right again after a serious dismantling, before I have to drive it to work again. Like, a whole week's worth of daily shuffle.
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
