controller is too easy...I hooked up my wheel and hyperdrive, set it all the stuff off...and geez it is a lot better... mind you I can't control an MR car to stay on the track once the back end breaks but it sure is fun :(
Those that think the driving isn't 'realistic' enough for them really need to turn off t/c, asm, abs, etc. and you'll see how bad you really are...
been trying out B Spec...I dunno about you but it looks so pointless. There's really not much you can do in terms of management...and how do you make the time go quicker? GT4 you could do it double time to make it go quicker...
The amuse carbon R, you win it at some point (I did), so don't bother buying it.
are you f**king kidding me i spent 250 000 on it today..........
its lots of fun to drive. Not as quick as a fully worked R35 but more fun. Basically a carbon fibre RWD 34R
I finally purchased a R33 GTR and it's exactly like the real thing! Right down to the way the ATESSA-ETS catapults the car the other way if you counter-steer mid-corner with your foot on the accelerator! Not too sure about the sound of the engine though, my old rb26 didn't sound like that, lol.
do you mean to say people actually use all that BS? i've had everything off, except abs on 1 because i would lock up every time otherwise. the joys of the controller
yup, all the TC etc off, except 1 notch of ABS. only way to drive.
i prefer to do it more like how the car comes from the factory. old cars i turn abs off. new cars that have abs standard i leave it on.
shits me off when people say "pfft, you are driving with abs on, i have it turned off so it's more realistic" when you are talking about a car that has abs standard, because it would be more realistic to leave it on and possibly even turn it up a few notches, LOL
    • https://www.efisolutions.com.au/coolant-temperature-sensor-bosch-180sx-s14-s15-r33?gad_source=1&gclid=CjwKCAjwzMi_BhACEiwAX4YZUHsCQhbiDT_NC3q5wD9jrzH6Dts9eGSr19NXSDw7x9WVm1sH7G3S4hoCwaUQAvD_BwE this is the one i replaced today
    • I have replaced the larger coolant temp sensor, i do see a smaller one next to it (looks to be just 1 pin) but i assume that is just for the dash? or should i replace that aswell?
    • Check coolant temp sensor ~ symptoms fit the hard hot start/cold start OK scenario --- if sensor goes open circuit, ECU thinks engine is cold and enriches mixture ....works when engine cold, but floods them with rich mixture when hot (Hyundi MAP engines are a bit infamous for this)...
    • OK, starter changed for a spare without much trouble. Neil had kindly left space to get to the top starter motor bolt from above with a long spanner which makes the whole deal much easier, and everything else was neat and easy to get at from underneath. Once the starter was changed everything was good, unplugged the CAS and turned the motor on the starter to make sure everything was free and happy. Onto properly priming the oil and first start. I'd picked up one of these oil prime kit from Boost doc a while back and this was my first time using it.  https://boostdoc.com.au/products/engine-oil-prime-kit?_pos=1&_sid=28c628a65&_ss=r While I'd organised all the fittings to hook it up to my GTR (sump plug to -6 feed and -4 T to tap it in and retain the oil pressure gauge, neither suited on this car as the oil pressure needs to T into 1/8 NPT not -4 and the Aeropro sump has some massive drainplug not that factory whatever it is. So, waiting for a couple of fittings, then I'll prime it and do first start, hopefully next weekend. Other than that going well, there is very little stopping a final alignment, tune then shakedown day
    • Also to mention, i just tested the CAS, seems to be working fine, can hear the pulses inbetween 0 and 180 degrees, another mention aswell, when i let the car sit for about a hour today, i went to start it and it almost fired on first crank, then just completely struggled. Could it possibly be blocked injectors?, maybe allowing a little bit of fuel to seep past allowing it it almost start first crank?
