been offline for more than a week...get back and its a big patch. yay. got my '88 countach from the online collectors garagee.
some cool pics, and mighty amounts of game play you guys have been doing by the looks of it. keep it up
oh, anyone played with the clutch much??(G27)
ive read you need to press triangle and blah blah blah before the race starts but after it loads and yadda yadda.....all crap
it works fine, just make sure you use it for every change after touching it, dont flat shift (which is a bit lame), and dont miss anything. it is very rewarding to use once you get used to it. makes for much smoother downshifts especially in that dambed top gear challenge in the lotus
i can only manage 1:37's in my R33 GTR V-Spec LM Limited
Had to detune it to get it into the power range lol. Still, not sure how your supposed to do it in this GTR, looks like the newer the GTR the better
lol.. u said r33
So I see on GTP yesterday that you get 3.7 million xp for winning the Nür 24Hr on B-spec. God only knows how much you get on A-spec; ~6 mil?
Of course since you're already at lev 40, it makes no difference to your levelling- But what an awesome way to turn noobie Bobs into track-meisters in one hit.
Have you reduced the weight of it? but as i said, in my r34 n1 i could only get 1.31's so i hd to use an r35. From memory i didn't change the oil because that would've put me over the power limit so i just put a basic air filter on it and that took it to exactly 493. i also had aero mods on it too
i hope so. hes a average-slightly cool driver, and yet gets flustered and easily hits red while im telling him to ease up. not until he poorly overtakes everyone does he then settle and get into a good rhythm. mind you i only just started B spec...lvl 4. i just dont like doing mods to crappy little cars that won the A spec stuff for me easily
Yep R35 v spec is the way to go..... took my about 5 goes to learn the track properly but I got gold. Struggling with the Fiat challenge though I can only get silver anyone got any tips for golding it?
i didn't even use the v-spec. i just used the normal one and saved myself 100k, LOL
as for the fiat, i too have only got silver. my last attempt i was 2 seconds behind. the big thing i found is that after driving plenty of fast cars, with the fiat you have to remember that you are going much slower, so you ease off the brakes a bit sooner otherwise you wash off too much speed. also on the last corner you can hold it flat the whole way round, however this causes you to run a bit wide, so if you lift off a bit and get a straighter line, and if you are using an auto it should drop back to 4th which will give you better acceleration. if you hold it flat you end up going the same speed at the end of the corner but you are still in 5th and don't accelerate as fast. also draft down the back straight as mush as possible.
what I've learned is when you get a chance to create a driver soon, keep hitting the 'new driver' button until they have as much attitude as possible: it makes them quicker in the long run (which is what you need for being able to start a race and come back hours later to a win)
yeah but the flipside to that is when they're battling an opponent and they're meter goes all the way into the red they'r almost definately going to have a fantastic crash. if your not cheating and your using a proper car so as not to give yourself a stupid advantage then that would probly cause issues?
yeah your both right. it does cause isues. but i can see what shaun is getting at. i would like to be able to walk away in the big races...at least for a while. ill make sure i have a driver on both ends of the scale :)
hot-heads all the way baby
I was winning the Roadster 4hr by 16 laps using a heavily modified car. the ones with maxtreme attitude are always keen to maintain their lead or overtake lap traffic. recognize
Sounds good to me. Only just picked up my second driver (don't get much time to play :() and made sure he was a hothead.
My coolheaded driver doesn't allow me to walk away from a single B-spec race. Even in the early races against 300ZX's etc he becomes so complacent in the 650+hp LFA that he will drop his half lap lead and let others overtake him.
Looking forward to just letting a driver drive on his own.
yup- that's why I retired the cool driver I got second and started again. He was rubbish at being left to it.
Anyone looking to buy a HKS PS3 Racing Controller? I think I see one for sale somewhere cough cough :whistling:
pretty sure someone in this thread bought one. personally i wouldn't waste the money, especially just because it has HKS on it. just get a white-out pen and write HKS on your controller.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
