I got the Toyota minolta 88C-V last night, and added a turbo, 1080hp i think, its fast and pretty good but my god its twitchy, Mind you im playing with a controller and traction control and ASM on so when its oversteering its catching the car and putting fairly bad understeer into it which shoots it straight off if your not careful. Has anyone found a way to fix this?
dont be useless. lose the extra turbo.. lose the TCS.. lose the ASM.. even with the controller its not hard to feather the throttle where you need to. dont forget those le mans cars are engineered to only turn properly at high speeds or under throttle, so if you slow down to much and have no throttle on going through a corner you will be absolutely murdering your potential lap time. even on extremely low speed corners you need to be at least partially on the gas through the corner to maintain proper grip and neutral steering
the same applies for virtually all le mans & F1 cars
But more power is always fun :P
Think it's just the asm catching the oversteer and making it unpredictable. Will have a go with it off next time. Need somewhere to clamp my wheel and pedals so I can race properly
Edited by 89CAL
Anyone else on here got an X1?
If so, what's your best Tsukuba lap? My best so far is 29.6
I got one last night that thing is stupid fast and hard to control with a pad, i did probly 10 laps with it and my best was a very very sloppy 32 something, I need lots of practice just to keep it on the track it is just so fast.
accelerating very slowly- the bumps knock it around quite badly, and it's very twitchy with the d.f set to minimum. also realized the toe-angles were set to - and +1 front and rear standard, which may have scrubbed some speed. car makes less power now so there's no point trying again
it's geared to do 507 (which you can't change), you should be able to get 490 or more if you cruise up behind a Le Mans car 3/4 of the way down the straight and get an aero tow
I think I only managed 420 or so in the veyron, but that was just a practice run to see if it would hit 400 with no other cars on the track. got my 111 feet per second or whatever it is lol so i was happy. Been hitting B-spec lately. My hot headed driver is getting quite good at level 12. Nowhere near as much frustration
farkk it.. old ps3 packed up good and proper last week. just went and bought a new slimline. how lucky was i to backup my gt5 data about 2mins before it broke.. although all my other game saves are down the tube.. ffs sony needs to sort their shit out and come up with a way to transfer saves off the old hdd
erm, doesn't the "backup" utility do this?
I upgraded to a 500GB HDD and all my save games went across no worries. Just needed to re-sync the trophies.
i didnt upgrade, my console died. making it impossible to get access to my saves.
one time i tried the backup utility it tried to backup everything on the drive, movies, music, the lot. didnt have a flash drive big enough for it. i only need a backup of saves but it doesnt let you do that
I know, but you could still remove the HDD from the stuffed PS3, put it in the new PS3, perform the backup to an external HDD then put the original HDD back in the new PS3 and "restore"
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
