Would like to know what car you have used to win the All Stars Championship in Expert?
I have 2mill to play with an was thinking of a full tuned Mclaren F1 94'?
I tried with a full tuned 458 and came 4th.
Any suggestions?
Im using the GT500 R35 and can manage 3rd.....need maor cashola for a LMP car
yay for update. Performance Points, remote mode and better Ai is all detailed in the patch notes. but things like the new tracks (which i cant find anywhere except in the seasonals), and the fact that it tags which cars you own in the used car dealerships now, isnt mentioned at all in the notes.
but i must say its the best update yet...the AI cars arent immovable bricks, they can be bumped and actually realise your there!(to some extent)
the Eifel track is sweet, took my old FD RX7 for that race. lots fun to be had, and MONEY...money money money!!
havent tryed the remote Bspec yet. but will def come in handy on office days
Remote b-spec mode available now. Anyone given it a go?
Yes it's sick. I just came home from work and my drivers bust have been used a fair bit because they had earned me 0ver 1.8 m today alone. I will host some races tonight to return the favour though.
Can you explain how that works?
Do you just leave your PS3 on or do you manage the races on your work PC via your browser?
from what i gather, you need to hit the remote play button on GT5 then you can access via the GT site
If you want to host the races you have to leave your PS on and in server mode but thats not what I do, I just leave it switched off during the day and people on my friends list just use my drivers in their races, it only works if you have friends that host races. If you have computer access during the day you leave it on in server mode and host races as much or as little as you like.
Edited by NISMATT
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
