  • 3 weeks later...
i had to reformat my ps3 today. reinstalled gt5 (twice due to it being stupid). then had to download all the updates. fuck me that was a pain in the sphincter. about 2gb to download all of them. after downloading and installing half of them an error occured. even though it had installed 5 of the updates, because of the stupid way it does it, i had to start all over again. 2 of the updates that it had already installed were 608mb and 1192mb, which it had to download again. so it took about 5 hours all up to install and update. really wish they would allow you to download the game updates on a pc to the install via usb, like you can with system updates. would mean that you could just download each new update as it gets released and then if you have to reinstall the game you can just plug in a usb stick and apply all the updates from that.
cant say ive had an issue like that.
When switching consoles from my old YLOD model to my new one, it was a simple transfer (after getting the old one running again)
otherwise the only time ive had an issue of it dropping out is on my brothers PS3, when we installed GT5 we also had 4 other comps interneting at the same time and it had a little error in the last 3% of the updates (all of them):angry:, but it had only forgotten about 300mb the next time round. so no big issue
i feel your pain, just spend the last 6 hours ridding my PC of a virus, and attempting to recover lost data.
completly ruined my GT5 session, was half way through a dam race too >_<. but almost done, i'll be online racing for quite a long time tomorrow
so drop into the room and have a few races if you guys are bored. i'm usually in the Japanese GT300/GT500 rooms
i have it drop out all the time when doing updates over wifi (router boots it off. router is a piece of junk. restarts itself every few hours). this time i had it connected via ethernet and it was when it was installing one of the updates that it got an error, not a connection issue.
New Dlink router with Wi-Fi less than 100 bucks!!! win. i had to replace mine recently due to a lightning strike (which also fried the Network plug in my Comp :( )
Coincidence! My router got fried by lightning strike last Friday night and then was pronounced dead on Monday.
On the plus side, Harvey Norman have 30% Cisco stuff at the moment so I grabbed an X3000 which is performing very nicely :)
  • 9 months later...
I know the new Vette is now available on a DLC pack, if that's your thing
I'm keen on finally getting the Spa circuit, and adding the Aventador would be good
But need to do my first ever system upgrade on the PS3 in nearly 3 years beforehand... as soon as my data allowance rolls over for the month, lulz
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
    • Yeah, but it's not "boost" that they can take more of. Well, I guess it actually is. They are the same turbine, driving different compressors. I think the failure is more of a turbine temperature and (probably mostly) speed thing. I think the RB25s end up needing the turbine to reach higher speeds in order to drive the compressor to achieve the same boost level. So they will fail at lower boost on a 25 because they've actually reached the same failure speed that they do on a 20 at a higher boost pressure. If that makes sense?
