I got the Toyota minolta 88C-V last night, and added a turbo, 1080hp i think, its fast and pretty good but my god its twitchy, Mind you im playing with a controller and traction control and ASM on so when its oversteering its catching the car and putting fairly bad understeer into it which shoots it straight off if your not careful. Has anyone found a way to fix this?
dont be useless. lose the extra turbo.. lose the TCS.. lose the ASM.. even with the controller its not hard to feather the throttle where you need to. dont forget those le mans cars are engineered to only turn properly at high speeds or under throttle, so if you slow down to much and have no throttle on going through a corner you will be absolutely murdering your potential lap time. even on extremely low speed corners you need to be at least partially on the gas through the corner to maintain proper grip and neutral steering
the same applies for virtually all le mans & F1 cars
But more power is always fun :P
Think it's just the asm catching the oversteer and making it unpredictable. Will have a go with it off next time. Need somewhere to clamp my wheel and pedals so I can race properly
Edited by 89CAL
Anyone else on here got an X1?
If so, what's your best Tsukuba lap? My best so far is 29.6
I got one last night that thing is stupid fast and hard to control with a pad, i did probly 10 laps with it and my best was a very very sloppy 32 something, I need lots of practice just to keep it on the track it is just so fast.
accelerating very slowly- the bumps knock it around quite badly, and it's very twitchy with the d.f set to minimum. also realized the toe-angles were set to - and +1 front and rear standard, which may have scrubbed some speed. car makes less power now so there's no point trying again
it's geared to do 507 (which you can't change), you should be able to get 490 or more if you cruise up behind a Le Mans car 3/4 of the way down the straight and get an aero tow
I think I only managed 420 or so in the veyron, but that was just a practice run to see if it would hit 400 with no other cars on the track. got my 111 feet per second or whatever it is lol so i was happy. Been hitting B-spec lately. My hot headed driver is getting quite good at level 12. Nowhere near as much frustration
farkk it.. old ps3 packed up good and proper last week. just went and bought a new slimline. how lucky was i to backup my gt5 data about 2mins before it broke.. although all my other game saves are down the tube.. ffs sony needs to sort their shit out and come up with a way to transfer saves off the old hdd
erm, doesn't the "backup" utility do this?
I upgraded to a 500GB HDD and all my save games went across no worries. Just needed to re-sync the trophies.
i didnt upgrade, my console died. making it impossible to get access to my saves.
one time i tried the backup utility it tried to backup everything on the drive, movies, music, the lot. didnt have a flash drive big enough for it. i only need a backup of saves but it doesnt let you do that
I know, but you could still remove the HDD from the stuffed PS3, put it in the new PS3, perform the backup to an external HDD then put the original HDD back in the new PS3 and "restore"
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
