Have you done like the wind ?> The final one ?
Basically, Buy a Corvette ZR1 or whatever the are from CHEV.
take it to GT AUTO
Perform racing modifications.
This should give you pretty much all the expensive shit in the tuning show (weight reduction etc etc)
Now go and fully tune the engine as far as it can go.
Buy racing softs.
You should now be able to win most races.
Win the "like the wind challenge"
You with the Toyota Minolta 88C-V, Give this car the biggest turbo upgrade and racing soft tyres.
You now have a car to beat any cup it is eligible for.
does rebuilding the engine and chassis actually achieve anything ?
I don't want to do a full 6 hours of testing at the ring to determine this.
beaten all races bar the bottom 4 of the enduro's and the Formula GT world championship.
rebuilding an engine will see you get an increase of hp (takes it back to what it was stock), so if you have a car that you have used a lot and it is down on power compared to when you first bought it and an oil change still doesn't take it back to full original power then a rebuild will.
don't know about the chassis one though.
take it to GT AUTO
Buy racing softs.
Well didnt work....will have to slug it out to 5mil credits the old fasioned way
Yeah Zebra,
What exact car did you buy.
If they are catching you make sure you play with gear ratio's depending on the track.
I found I could go a lot closer on Daytona Infield circuit and then of course open it right up for Indy.
It wasn't a struggle, it should be a pretty easy clean sweep for you.
the prob I have is getting past the cars through the infield, no where to pass/or you just get bumped off....it shits me that there is no quali...fkn over starting in 7th all the time
Rolling starts also shit me to tears
Im almost to 20mil thanks to remote bspec haha
hahaha, yeah thanks for that. i log in every week or so and retrieve the prize money i've gotten thanks to you and a few others. if i have time i run a few races to pay you back a bit too.
zebra i sent you a friend request on PSN ages ago. i could've earnt you a heap of money over the past few months had you accepted, LOL
    • Depending on exactly where that voltage is being measured, that is most likely the battery is f**ked. If the multimeter probes are on the battery's own terminals, then it is f**ked. If they are on the car's terminals, then there is a bad connection. Either are fatal to the attempt to start it. Literally just put it on the 20VDC range, put one probe on the battery's -ve terminal (ideally not the car's terminal) and the other on the block somewhere exposed/metal, like an engine mount bolt head. You can also test the earth lead is steps, so from battery to body earth, body earth to engine connection point, engine connection point to some other spot on the engine, to see if you can isolate where a shit connection actually is.
    • I meant to write 50 originally and then double checked the price and found it was ¥12m (125k) and came to edit it and realized I had accidentally added and extra 0 in the first place lol
    • I wonder if the n1 was cheaper when bought new
    • Only reason I started replacing hoses was I went for a short drive to the shop the other day and finished shopping and started the car and started to drive off and could see a big trail of fuel in the rear view mirror. Parked up and found the bottom hose to the fuel filter had busted. Lucky I was near a car part store and was able to get a replacement hose and back on the road. But got me thinking I had owned that car for around 20 years and was all original fuel hoses so probably time to replace all of the fuel hoses. Was pretty lucky it went where it did.
    • A few kg falling from a few feet is enough to move parts of your skull inwards into your brain Also, there's always news about people getting crushed, and occasionally killed, working under cars Be safe is your endeavours
