Nah it's not that your ps3 and router don't get along, ps3's just have crappy wireless hardware. Mine sits less than 1m from my router and it still disconnects during games and downloads really really slow. Swapped to cable connection and it's all good.
no such issue here, mines always been wireless and have never had an update go askew or a drop out...unless the modem/router has a tantrum, but that effects all comps on my line. it is a bit slower on the DL's but not enough to worry me.
I bought an EoP (Ethernet over Power) set for mine. Plugs into the wall at your router and turns your power cables into a network basically. Just plug the PS3 into the wall unit with a CAT5 cable and works a treat :)
I got sick of constantly getting droupouts on my PS3 and t-box so now I have a 5 port router in my room so I get "wired" internet despite the fact the actual router connected to the internet is several rooms away.
Yeah I've never really had an issue with dropouts on updates, they are just really slow. Last one was some dlc, 500mb and it took nearly 2 hours! The dropouts happen more during online multiplayer, gets really annoying, never had an issue with wired.
What's the speed like in those ethernet over power setups? I had them in mind to extend my network but just ended up running a length of CAT5 under the house.
Edited by QWK32
What's the speed like in those ethernet over power setups like? I had them in mind to extend my network but just ended up running a length of CAT5 under the house.
They're rated at "100mbit", and through tests I'm currently getting about 87-93mbit. So while not fantastic, they're good enough for media streaming, and updating on the net.
Some of us live in apartments ;)
yeah you wont get amazing speed out of them but should be enough to support max speed on your ADSL+2
download speeds on my PS3 seem good anyway. Had some trouble with mine recently not connecting (the two EoP units) but up until then It ran faultlessly. Still not sure what happened but I've moved some stuff around and its all good again
nah it's that my modem is a kill joy. when i go into the logs in the modem it shows that it has booted the ps3 off each time. the modem has issues though. probably 10 times a day it will boot all computers off and sort of resets itself.
i have a long phone line somewhere, and a few metre long ethernet cable, so i'll bring the modem to the ps3 i think.
+1 for new modem.
Spend the few extra $$$ for one. You'll be glad you did.
I had low end linksys which would give me grief all the time. Would never hook me into a cod match.
Changed it over to a high end d-link and haven't looked back since. Over the three years I've had it, not ONCE has it dropped the connection.
i was using a high end draytek at my parent's house; since moving out i'm just using the one optus gave me... no problems at all; torrents run fine with however many connections in the NAT table, no dropouts during games.... is pretty friggin good for a basic modem
just saw that in the DLC content coming out next week there will be Spa Francorchamps (with weather effects)
F$%@#$^!@ excellent!
Spa is my all time favourite track and think its one of the better real life tracks out there, def downloading this :)
i seem to find it easier to drive when i'm using bonnet cam. if i use the bumper cam i cant hit the apex's right and i end up being 2-3 sec slower per lap
funny how a slight change in view can cost you that much time.
Edited by liger
    • I’m hosting a bunch of execs in the McLaren box on Saturday. If you’re around I’ll come say hi, and see if I can sneak out some freebies.
    • Yes. All of this. But even when you get the NOx as low as you can go on an RB, it will no doubt still be way too high. Same with CO and HCs. The tech and the tuning time just isn't there.
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
