No xr6 turbo sadly , gt4 was fun with that car ,
just bought the 2j chapperal a cold hard 14mill.......
xr8 pops up in the used car lot but very rare took over a yr for me , now i see it everynow and then but itd 1.5mill and cant be sent
curently doing the bspec online sesonal event and earning 4 mill for 30mins
the chaparel is going to get nerfed in the next update from what i read. the fan that sucks it to the ground is going to be better represented as down force.
and a new car pack etc. aswell as test coarse! YAY finally a premium Beetle. cant wait
CLICKIT!!!
will add you as soon as i get back on the PS.
the monaro/commo is in the used car dealership, you just have to keep an eye on it and check regularly enough. (on this note. if anyone happens across a 400R they dont wanna keep, send it my way "Resnort", as i want one to fully modify. so i can keep my current one standard )
the XR8 as far as i know is only the old AU touring car isnt it?? which you win along the way somewhere, but also comes up in the UCD
The 400R is now available in the Online Collectors Dealership. 120,000.
CLICKIT!!!
The new beetle is entertaining, I modded mine and it tries to pick up the inside wheels and roll over all the time lol.
The AU V8 supercar is a fairly disappointing drive you're not missing much don't worry.
Edit: If duping cars is still possible more than happy to send it to ya.
i liked the xr8 in the older games. sure it isn't the fastest thing in the world, but it handles ok, and if setup right it's good for sliding around the track (without full on drifting).
ok so i bought a few beetles..... one is fully blown with both stage 2 and 3 turbos, the other ive done up to have the HP and look of my actual beetle....
they look fantastic (other than the usual lack of wheel choices), and actually handle quite well..............but, they got it entirely wrong with how they take off, and the weight of the car. over 1000 kg fully reduced is still 200kg over standard empty weight. but thats not what "bugs" me, the fact that a 200hp beetle cant spin the wheels from a standstill is just wrong.
at first i thought, oh thats just the stage 3 high rpm turbo kit.....so i tryed the others and still nothing. now i drive full clutch with a G 27...and no amount of clutch dropping fixed this.
so then i built my second bug, to replicate mine as best possible. 75 hp with what is alot more mods than my actual engine has to achieve the same result, then put it on the test track.......11 seconds to 100km/h. WRONG! and a 19 second Quarter...also quite wrong. and the same issue, even with comfort tires its a chore to get it to spin the wheels and the launch off the line is nothing like it should be :(
rant out, i still love em, and having a lot of fun driving them.
anyone been working on setups for the SS route X ?
i've managed to get bugatti up to 446km/h , but i've seen people go much faster than me ( i estimate about 460km/h). i've tried fiddling with the gear ratios, aero and suspension setups. but cant seem to crack the 450km/h mark.
any ideas?
aero as low as it can be, no slipstream. gear ratio's set to a top speed of 460km/h ( tweaking of the final gear).
If i bring the final ger ratio so its set to a top speed of 470km/h, it will actually lose about 4-5km/h from when the gear was set at 460km/h.
ride height at its lowest ( F/R)
sway bars at 7 ( F/R)
running soft slicks
between 1/4 -> 1/2 a tank of fuel with i do my timed runs.
i just cant seem to figure out how they can reach that speed.
running soft slicks
what about if you set the gear ratios so the top speed is only about 465kmh? maybe try putting the front aero up a bit (doubt it will do anything, but worth a try).
just looked at a video or 2. one said that you tweak the diff settings (initial torque to minimum), plus low suspension rates.
is it possible that the track has a slight incline in one direction? maybe try spinning around and heading back in the other direction and see if it makes any difference.
Thought I'd get my b-spec drivers to start doing more endro's so I did the Laguna Seca one with the little caterham fully worked, the thing did 70 laps before pitting due to the tyres, and if it had an larger tank by 4 litres it could of done the whole race without refueling LOL
Edited by HR31_RB20DET
GT5 shits me sometimes... I did a huge update on Monday night (made bigger cuz my shitty wireless broadband is slow), and then i turn on tuesday night... another update! This one only 80mb.
I'm not shitty that they improve the game... i just hate my internets! /Rant
Loving being able to change rims on standard cars now.
finally got my pics off the PS3. heres some of my cars. the McLaren is just mental fun
Found em! nice.
Maybe we should have a sub-topic for GT5 photography. I get bored enough to actually do this crap... and obviously so do others (tho probably not many).
made this a few days ago.. monday i think it was.
i love this sort of close racing, especially on the test track
sorry about the small video, you'll probably need to view it full screen or in the larger player. i was concentrating on fast upload rather than the video size.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
