Hi guys I have just bought a R33 GTS-t and have spent a bit of money on it. would just like to know how much power I should be looking at. it has
N1 oil pump
RB26 crank and rods
Ross Forge pistons
1.6mm copper head gasket
N1 water pump
Gates timing belt
4 angle cut on the valves
ported head
cams have been re-profiled
HKS adj cam wheel on the exhaust side
740cc injectiors
Nismo Fuel reg
Bosh 044 fuel pump
Hi mount Turbo manifold
Garrett GT35/82 Turbo
46mm wastgate 15psi
full 3" exhaust
Apexi Power FC
I think that is every thing any help would be good.
https://www.sau.com.au/forums/topic/274785-how-much-power/
Need to know what dyno brand and model, how well calibrated the dyno is, what kind of tyres on the car, how much tyre tread left and how long a piece of string is.
Or go pay a workshop a few bucks and they'll dyno it for you and you'll get a better accurate reading than asking on an internet forum.
https://www.sau.com.au/forums/topic/274785-how-much-power/#findComment-4657310
What's with the seemingly venom-laced replies? Warm welcome for a newbie...
The man is just asking for a ballparker on that equipment. I think he knows he's not going to get a decimal readout and torque curve from you guys. I too would guess about 340kw @ the treads minimum.
https://www.sau.com.au/forums/topic/274785-how-much-power/#findComment-4658336
+1, Welcome.
You,sir, will make a lot of power with all that on the car, but just book in a dyno run soon, somewhere reputable, and you'll have it on paper
https://www.sau.com.au/forums/topic/274785-how-much-power/#findComment-4658350
Hi.
If you take the time to read the RB25 and RB26 Dyno Sticky threads... located here:
http://www.skylinesaustralia.com/forums/Rb...yno-t93880.html
http://www.skylinesaustralia.com/forums/Rb...yno-t55845.html
You will soon see that somewhere around 350-370rwkw with a good motor is what to expect... your limiting factor will likely be the 3" exhaust.
Please read through the Dyno Sticky threads i have linked above, compare mods and the power outputs and you will see any other flaws in your setup.
At the end of the day, what it makes, is what it makes.
Your tuner will let you know where the problems will lie once you reach that point
Cheers
Ash
https://www.sau.com.au/forums/topic/274785-how-much-power/#findComment-4658361
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
