Dyno tune results
borry
 Share
Hi All,
Got my car back from Unigroup Engineering! I had the guys replace my stock injectors with SARD 550cc units, replaced the stock ECU with a Power FC and the stock fuel pump with a Nismo fuel pump.
Before we started i asked the guys to iron out a few flat spots that i was encountering with the original setup. THey managed to eliminate the flat spots and gained a large amount of torque along the way :)
Ive attached the dyno results which show just how much power and drivability was gained with these 3 mods.
The RED line on the dyno represents the car in "stock" Exhaust, intercooler and a little boost.
The BLUE line represents the car with the tuned PFC, Fuel pump and injectors @ 10psi
THe GREEN line is the same as the blue line but with 1psi of extra boost (11psi).
As you will notice the boost starts to die off from 5500rpm which indicates i need a larger turbo ;) (next mod)
I absolutely love driving it now with the bucket loads of torque, im ry happy with the results and the quality work performed by Unigroup Engineering.
 Share
