Item: 97 Nissan Stagea rs4
Website: Here and Boost
Item Condition: Very Good, Few Scratches
Reason for Selling: Wanting A Ute :P
Price and Payment Conditions: 15,000 or swaps for vu, vy, s or ss ute
Extra Info: Manual Conversion(done 5,000ks ago), GTR Gear Box, Xtreme XHD Clutch + Xtreme Lightweight Flywheel, Filter, GFB Bov, Isotta Bucket Seats with mod plate, R33 Brakes, Slotted Rotors, Performance Pads, Tien Coilovers, 19"Advanti Vienna mags, 3" Turbo back Exhaust. 157,xxx on clock, Sony Head Unit, 4 Pioneer 6x9 + Stock Tweeters. Sounds great, drives smooth and sharp. All mods have been done in the last 9 months, car has never missed a beat, 2nd owner in Oz, prev owner used it as family car so hasnt been thrashed.
Pictures: yes, sits a little lower now than shows in photos
Contact Details: Contact me here or msg on: 0434623014
Edited by Stag_79
https://www.sau.com.au/forums/topic/274810-97-stagea-rs4-manual/
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
