hey hey
i need a standard front pipe 4 an EPA on thursday (pipe just b4 the cat soz if i got the name wrong)
iv failed it once with standard exhaust and i cant use restricters in the piping.
can some1 please help me i can pick up and drop bk off
im living in the cheltenham area
many thxs
https://www.sau.com.au/forums/topic/274829-help-with-front-pipe-4-epa/
did you fail on noise, or gas readings?
because the front pipe shouldnt have much to do with noise or the gas readings
make sure you've got a std. catback and that should easily pull you under 91db
i have a standard cat bk
but an apexy 3" in front pipe
so im getting 85 at 4.5K
but goes up 2 91 after he takes his foot off
this was all tested with me not there
so im taking his word
done at indy motor
as can only do it there or some place on other side of city
Take it out to Lilydale, they do the test properly in an open area.
If its 85 under load, I'm VERY surprised it would be 91 on backoff mate. It should be 2-3dB... not 6 (which is massive)
And you can use restrictors, you need to fully weld them
apparently only 2 places can do the epa in vic
one in keys road morabin
and one in i think malvin
and Benzino33 that would b mad i cant PM yet need a few more post as soon as im at 10 ill pm u
ummm, there are about 20-30 Approved EPA Testing exhaust workshops/businesses.
apparently whoever told you that, is wrong :)
Oh sorry bro, I was out for a bit. yeah be glad to help out. My number is 0401157085, give us a call or msg me. cheers
BEn
No he is correct. He is going in for the full ass rape. I got an epa 2. Only those 2 addresses on the letter.
BEn
hey ben i tried calling and msging u
if u can give me a missed call on 0434110778
ill buz bk straight away
thxs gary
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
