Nah, It was more of a rhetorical statement rather than a factual comment. Wasn't saying you said otherwise but just making an observation that if he had the second tune done at Dyson, it would more than likely rule out bad tuning.
Oh fair enough.
Completely agree :)
Maybe i missed it, did Dyson tune it the second time?
Dyson had done the tune befor i bought it and it was running great. But then i went and changed the top end then dyson retuned it for me and made 490 at 20psi. was running wicked under boost but too fuely at idel. Then i had a bit of a missfire. so i took it to the local guys. They said the tune was done the old school way and that they could get heaps more power. So they made me 430 at 24psi. YAY. And to fix the miss fire they sent the microtec of and said it was the problem. them said it was the harness so they replaced it. Then still missfired so they replaced my no1 coil for $40 that fixed the prob. Then they gave me a bill for near $2500 they wont give me a timming graph. Said they cant get that of a dyno tune. but ill scan the results from dyson and the results for the local boys T.A.S.
^^^ there's the issue.... "the local guys" :P
Edited by URAS
So you are saying you had 490rwhp then took it to another tuner and they could only get 430? nothing mechanical has changed ?
Link make the ECU which calls the shots on the fastest RB30 powered car in the world (may be the quickest RB in this part of the world not running meth too?).
So what? Cars that are even faster, much faster, don't have ECU's at all. So we should all change to that fuel injection system? Why not, based on your rating system, it's better than a Link?
Cheers
Gary
Cheers
Gary
Mechanical injection is superior to Electronic injection in nearly all applications...so yeah, we should all change to it.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
