Keeping with the current trend of mods......
just some more rice arrived on my door step to go on the car.
Ive been ordering alot of simple mods in which i can install myself
So these turned up..........
NRG Carbon Fiber Hood Dampers
These are some pretty good quality hood dampers and apparently can support the stock and also aftermarket hoods.
Not only is it great to show off when you open the engine bay, but it makes working under there alot easier. It also raises the hood alot more than with the stock hood prop. IMO all cars from factory should come with these things!
Installation took about 30 minutes, and was very easy and straight forward. There is alot of info and DIY on these simple mods on the US G35 forums.
Here are some pics, just finished installing them not long ago, its a bit dark!
Also, the Motordyne Iso Thermal plenum spacer i ordered arrived, so looking forward to do another DIY on that item :)
-mark
https://www.sau.com.au/forums/topic/274898-nrg-carbon-fibre-hood-damper-review/
Nice Mark,
Looking forward to receiving my spacer from you also, once all the items arrive of course, what a pain.
I was thinking of getting Hood Dampers for mine also, saw them on the Riverside eBay Shop.
How much did you pay for yours? And where did you get them from?
Thanks mate.
Nice Mark,
Thanks mate.
Got them from a trader on G35driver.com "JDMAutosports"
Ryan is excellent with communication, he is one of the best sellers i have dealt with over there. Ended up paying around $190 AUD delivered for the Carbon Fiber ones.
Nice work Mark, did you have to drill any holes to attach the struts or is it just using what's already there?
I'm not sure why the car didn't come with them in the first place? After all, it's meant to be a luxury sports. :)
yeh you dont have to drill anything at all.
all you have to do, is remove 1 bolt from the fender, and replace it with their own bolt.
then, you just remove the plastic cover over the hood hinges, and then remove the top bolt, and slide on their bracket, and put the bolt back on.
its such an easy installation to do.
hate to butt in, but $190 is expensive (and I just wanna give you guys the heads-up). I got mine for approx $100 delivered from Taiwan and they are carbon fibre look also...
http://www.skylinesaustralia.com/forums/V3...ay-t276863.html
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
    • You reckon? I have to disagree. Notwithstanding that at some point we may all be forced to do this to our cars if we want to keep driving them, there is absolutely nothing about an electric-converted-previously-IC-car that is ever good. EVs that are built by OEMs on platforms that were originally IC already suck, let alone the shitty outcomes that result from doing it as a retro to something that was actually built as an IC car. This is because the platform really needs to be designed to house the battery in a useful place (ie, down as low as possible) and the motors are properly located relative to the wheels that they have to drive. Converted platforms already suck at this. But when you try to shove sufficient battery capacity into a previously IC car, you can't put it down on/in the floor, because that space doesn't exist. You can't find enough space where the fuel tank used to be (if it is an inboard fuel tank) and you don't want to hang it out behind the rear axle line if you had a rear fuel tank. And there's not enough space in the tunnel if you still want to use it for anything remotely like what it was originally used for. The engine bay is too big for a motor, and you'd really prefer that the motor for the rear wheels wasn't in the front engine bay anyway. And there's not enough room where the diff was for a proper man-sized E motor. And then.... there is the complete lack of soul and emotion that is provided by EVs. There are some cracking restomods out there. Like the Alfaholics GTA thingo. But it is petrol powered. Look at the alternative EV version of a GTA restomod by Totem. it is jaw droppingly beautiful. But by all reports is is objectively awful to drive, despite having 600 HP or something, simply because there is nothing there. It sounds like a sewing machine or a leaf blower. It should scream and wail and make the hairs on your neck stand up. Oh, and it's 1500 bloody kg in a car that was <900kg when new. GTRs are heavy enough as it is without pushing them up to 2tonnes worth of pork.
    • https://www.dezeen.com/2025/01/06/nissan-electric-r32-skyline-gt-r-godzilla-sports-car/   I reckon this is pretty cool. Lots of other Resto mods have turned to ev power.
    • hahaha @joshuaho96 the most action it gets is when I have to drive from West to SE VIC to meet the fam. Even then, it;s on highway cruising speeds
    • don't know anyone in this thread, but i just found it, read the entire thing in a few hours, realized greg is still posting progress, and just have to say, this is awesome. it looks awesome. 100% right about the Uras kit making it a pain to get on hoists...have the same kit on my 34 and it takes six 2x4s and race ramps to do it without taking parts off. this reminds me exactly of this thread. https://grassrootsmotorsports.com/forum/build-projects-and-project-cars/r63-amg-the-unicorn-of-my-destruction/110824/page8/
