So tonight after work I decided to clean my engine bay. All well and good, did it while car was running no problems.... I finish up start driving home and just briefly gave it a squirt and I got the dreaded miss... No worries I thought, it must be due to the engine clean I had just done.
I get about 3 streets away from my place and the misfire starts on low throttle, I pull up into my driveway and the car sounds as if it is running on 5 cylinders now...
I'll leave it overnight and see if there might have been some excess water that may have dropped into cylinders. Would anything else cause this though other than "your coilpacks are hammered" or "change your plugs"...
It must be related to the clean I just did, but if I have damaged anything in the process what should I be looking at?
Cheers.
https://www.sau.com.au/forums/topic/274909-not-another-misfire-thread/
it will more than likely be due to moisture as guilt-toy said. first look for any pools of water around the plugs. if there is use a compressor to blow the water out or tissues to mop it up if you don't have a compressor. do this before removing the plugs.
then take the plugs out and give them a wipe down with tissues, and do the same with the coils. stick it all back together and see how it goes
pull the coilpacks out. when i did my engine bay. i covered all the electrical components. still managed to get water into my coilpacks. on some cylinders the water completed covered the spark plugs. didnt take long to clear out and is also good as you can check that the coilpacks and plugs are in decent condition.
Was planning on doing your suggestions tomm. Weird thing is though, I started it today no problem until car got warm and I opened throttle a bit.. Misfire again even on idle.. Looks like a trip to burson tomm. For plugs and can of compressed air.. Will let you know how it all goes. Thanks for the suggestions.
I had a misfire problem for the past month after installing a new ECU, cam gears and injectors (R32 GTR). We replaced ignitor, coils, plugs, ECU - checked fuel filter, fuel pump, earthings etc etc - remapped fuel also. After doing this (all on Dyno etc) we still couldnt resolve it.
IT ENDED UP BEING THE EXHAUST MANIFOLD GASKET!!!
If you get nowhere on the electrics try to listen out for a hissing noise around the exhaust manifold.
this is due to the extra load once you get on the gas. very few missfires happen at low load
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
