Hey guys Ive done a search but cant much info on RB20DET aftermaket lowmount turbo extractors :)
Just need to know best brands for money as im doing a head stud replacement and thought I might upgrade the standard low mount extractors while they are off.
Only want low mount as dont really want the boys in blue on my ass for defect etc my ride is engineered but its expensive as people know.
Seen a few on ebay and on a few websites looking to spend around $500
https://www.sau.com.au/forums/topic/274924-rb20det-low-mount-turbo-extractors/
Yes it works fine up to about 300kw.
Lowmount or not, if the coppers see that big shiny aftermarket-looking manifold they will do you for it anyway.
You cant find any info on these because no-one bothers.
The cheap ebay extractors works fine. Before putting installation make sure you machine both flanges flat, and in most of the cases you also have to slot 2x screw wholes on the bottom (about 2mms each).
Point Taken :P Thought there might have been improvment over the stock one but sounds like the stock one is the go + Saving dollars to spend on ebc... HDI any good? :ermm:
yer there good what kind of boost do you think u will run
low mounts can maintain the heat shield modified and generally cant be seen really..
they provide a sound that a standard manifold will never get near and also when boost comes on its much harder
the cheap ones are terrible they crack in no time at all,
if you can find a jap spec one 2nd get it way woth it.
i have also had good gans with big porting of standard manifold, but nothing sounds like a tube low mount !
Atm running 14psi with dual stage manual turbosmart boost controller
Have thought about getting 6boost or spending 1000+ on low mount turbo extractors would love to have them they would sound really nice with my 3 inch system and hopefully get to 14psi before 4000rpm lol
thinking about putting a 26 in it need more torque!!!
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
