Hey guys, a few things I wouldnt mind offloading... Looking for a change!
Item: Garrett GT3040R, 0.82r, 0.70 a/r
Description: Turbo is brand new, I have the receipt somewhere. It has been running on my RB25 for about 5000km's on 16psi max boost. Made 360rwhp through a built auto and 4000rpm stall and I have hit 116mph with 1700kgs and woeful 60 foot time. Not laggy at all, can provide a dyno sheet if someone would like. Full boost by 4000rpm. Exhaust housing is ceramic coated, and will come with a dump pipe to suit external gate setup.
Reason: Genuine!
Cost: Not sure, $1400ono? Would like to get rid of it real soon so please make an offer!
Item: Japanese Exhaust Manifold, ceramic coated and match ported (not bad at all)
Description: Has been on my RB25 for about 10,000km and has flowed as much as 392rwhp through an auto box. Is in excellent condition, has some staining on the coating because of an oil leak but otherwise is perfect. Has not cracks. Has setup for external gate, which is loacted in correct position below the collectors. Have never had any boost issues.
Reason: Same as above!
Cost: $250
Will sell together cheaper if someone wants!
Oops. Contact Details - easiest just to pm me on here for now!
Cheers,
Matt.
Edited by cactus
https://www.sau.com.au/forums/topic/274928-rb25-turbo-upgrades/
is the turbo bolt on,if it is i am intereested in buying it,if not how much mods do i need to fitt it
Not really bolt on mate.
It would be best to purchase the manifold and external gate aswell... that way you would only need an exhaust and intercooler piping. But I would suggest fuel pump + possibly injectors and FMIC (might get away with using stock injectors) if you wanted to chase big HP.
look i am interested in both together where r u and wats ur best price
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
