Hi all, i have a set of Rays engineering TE-37, i have just got them bead blasted because i was going to get them painted and put them on my r34, but i have sold my car now dont have need for them, so they are ready for a fresh coat of paint, there are tyres but not on them, they are 18" 2x 8.5 and 18" 2x9.5, suits a wide body, looks good on a GTR.
if you have any questions please dont hesitate to call me on 0412 347 091.
Can paint them any colour you like.
2x Bridgestone Potenza RE040
235/40/zr18. 80% tread
2x Bridgestone Potenze RE01
265/35/zr18. 40% tread
Malbourne
$2,500
Edited by trbs
https://www.sau.com.au/forums/topic/274939-rays-te37-18inch/
originally of a R34
i think its a 45 off set
Best you confirm the offset that is stamped on the inside of the front and rear wheels. you're only shooting yourself in the foot if they are not as +45 is a horrible offset for those wheels.
The offset of the wheels are +37 on the 9.5, +33 on the 8.5.
so it suits all skyline including gtr, 200sx, 300zx, etc....
Malbourne
$2,500
Nice wheels man. I'm looking for a set currently... but the size and offset provided by u state that they are not suited for a GTR. As all wheel drive need to run the same wheel size all around.
What is the best price you can do? Considering it has weak offset...
Edited by Dush
hi mate, the best i can do is 2250 cash this week, thats probably the best i can do, what are you offering?????
come on guys it has to go
Malbourne
$2,500
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
