i dont know if they will be around, i cant help it if they sell this weekend, give me a call and we can work something out if your really intrested
If they sell they sell but if they dont just letting you know in a few weeks i'll be interested in checking them out, got bills n shit to pay atm.
Hi all, i have a set of Rays engineering TE-37, i have just got them bead blasted because i was going to get them painted and put them on my r34, but i have sold my car now dont have need for them, so they are ready for a fresh coat of paint, there are tyres but not on them, they are 18" 2x 8.5 and 18" 2x9.5, suits a wide body, looks good on a GTR.
if you have any questions please dont hesitate to call me on 0412 347 091.
Can paint them any colour you like.
2x Bridgestone Potenza RE040
235/40/zr18. 80% tread
2x Bridgestone Potenze RE01
265/35/zr18. 40% tread
Malbourne
$2,000
it has to go now, $2000 this weekend
Malbourne
$2,500
anyone
Malbourne
$2,500
make me an offer fellas
Malbourne
$2,500
update
Malbourne
$2,500
[/quote
update]
Malbourne
$2,500
$2000
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
