  • Replies 46
This is my Pedders experience.
Had the wheel alignment done on my R33GTS-T and it came back with a large scratch in the left rear quarter panel - which they obviously denied doing. Had a great fight with them when I asked them to use Gary's (Sydneykid) settings for the wheel alignment - they did it but with much complaining and probably resulted in the scratch.
Prices are very expensive - 12mm camber bolts Pedders = $115, Whiteline $79
The only thing going for them is that they stock front ball joints for R32/R33/R34 GTS-T's.
https://www.sau.com.au/forums/topic/274952-pedders/page/3/#findComment-4826267
so they measured up my car to see how much lower it will be with there sports ryder springs. (i have nismo s type struts and an unknown but firm spring, that i figured was stockish height)
aparently they will raise the car 10mm both ends. wtf type of lowering spring is that!!!
*starts saving for coilovers* (not pedders)
https://www.sau.com.au/forums/topic/274952-pedders/page/3/#findComment-4826489
meh pedders here don't even stock more than about 4 parts for R32 GT-R/4 suspension and the guy took a look at my car and says 'hmm haven't seen many of those', would rather get stuff done at goodyear - at least the guys there had a good idea of how an R32's suspension works!
https://www.sau.com.au/forums/topic/274952-pedders/page/3/#findComment-4826585
  • 11 months later...
Hi all, first time poster and owner of a skyline R34. went to get it looked at by a local mechanic coz the steering wheel was vibrating a bit on idle. He said I needed to get the front radius rod bushes replaced and suggested I go to pedders coz it's an import.
So I go to pedders and got them replaced for $260 but then they told me that they couldnt do the wheel alignment coz the steering gear is leaking internally and will cost another $1100 odd dollars to fix.
Just wanted to know if this sounded reasonable and should I be looking around elsewhere to see if it is bull. Can anyone recommend someone in melbourne, particularly in the western suburbs?
https://www.sau.com.au/forums/topic/274952-pedders/page/3/#findComment-5428632
No it's not reasonable. A second hand steering rack should only be 300 or so, and it isn't that much in labour to install. Also, I can't see how a leak would prevent them from doing a wheel alignment. Just go somewhere else to get the alignment done.
https://www.sau.com.au/forums/topic/274952-pedders/page/3/#findComment-5431439
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
