yeah, as long as cops cant see the light too brightly at night it should be OK!! just turn em off when you get pulled over, then they got no proof, cause you can have them installed just not on when driving!!!
https://www.sau.com.au/forums/topic/27498-installing-neons/#findComment-577420
I have them in my footwells and under the seats, looks awesome when the doors open, but couldnt tell if you were to drive past me on the street, just have a switch close by in the event of being pulled over and your set, no probs.
https://www.sau.com.au/forums/topic/27498-installing-neons/#findComment-578888
when i got pulled over i got let off for the neons in the footwells because they said as long as the neon is below the height of the steering wheel and the neon was not directly visible it will be fine, but i guess that can change from cop to cop...
cheers...ben.
https://www.sau.com.au/forums/topic/27498-installing-neons/#findComment-581272
Just thought I'd pop this up regarding the legality of non-essential lights in Victoria as it has been clarified to my workplace by the Police.
Following is an excerpt of a Road Safety statement as it applies to neon lights and such. Still trying to find an online link to the document but have had no luck as yet... (will keep looking!)
Road Safety
Non-Essential Lights
The boom of non-essential lights, including fluorescent lights under vehicles and the smaller ones on bonnets or wiper blades (generally blue in colour), on motor vehicles is continuing, creating confusion about their legality.
A little history about non-essential lights: the Road Safety (Vehicles) Regulations 1988, required motor vehicles and trailers to comply with the Standards for Registration (Victorian Government Gazette S15, 1 March 1988). Clause 702 of these Standards prohibited the fitment of lamps or reflectors that weren't required or permitted. The Regulations were repealed in 1999, as to were the standards, and replaced by the current Road Safety (Vehicles) Regulations 1999, incorporating the Standard for Registration at Schedule 8.
In making the new Regulations and Standards, Victoria adopted the National Light and Heavy Vehicle Standards. The current Standards for Registration, unlike the old, does not prohibit the fitment of lamps that are not prescribed.
What they do require, is for vehicles to be fitted with the lamps specified in the Standards and the Australian Design Rules. In addition, cluase 118(2) of the Standards allows a vehicle to be fitted with any other lamp or reflector, providing it does not show red light to the front, a white light to the rear or a light that flashes.
With regards to dazzling lights, clause 75 of the Standards stipulates a light (except a high-beam headlight), fitted to a vehicle must be built and adjusted to provide the necessary amount of light, without dazzling the driver of another vehicle approaching, or being approached by, the vehicle.
Additionally, if any light fitted to a vehicle (whether it complies or not) is used to dazzle, or in a way likely to dazzle another road user, then the driver may be charged accordingly (Road Rules-Victoria rule 219 applies).
The Macquarie Dictionary defines dazzle as 1. To overpower or dim (the vision) by intense light. 6. Temporary loss of vision, or temporary reduction of visual activity, related to the presence of a bright (possibly moving) source of light.
VicRoads' guideline (Vehicle Standards Information Sheet 8) permits the fitting of additional forward and rearward facing lamps, which comply with or are permitted by the Standards. Mandatory light fitted to a vehicle must continue to comply with the relevant Standards.
If a vehicle is fitted with lights in accordance with the Standards and used in accordance with the Road Rules-Victoria, then police can take no action. If a light fitted to a vehicle does not comply with the Standards, then a defect notice may be issued and the driver charged accordingly. As to the use of flourescent lights under vehicles and the blue lights fitted to vehicle bonnets or wiper blades, providing they do not dazzle other road users, they are quite lawful.
[End Quote]
So essentially in Victoria, as long as no additional light shows no red light to the front (making other drivers think you have your brakes on), white light to the back (making other drivers think you are in reverse), flashes or dazzles, you're clear.
This went through the courts here not long ago, where someone got charged for having windscreen washer LEDs. He won his case in court, and all fines issued to people for having these LEDs installed had to be reversed.
Hope this clarifies things a bit!!!
https://www.sau.com.au/forums/topic/27498-installing-neons/#findComment-583781
Wouldn't say they'd call neons a dazzling light.... Basically they mean any light that "blinds" you (high beams, spot lights, etc.) is a dazzling light. Neons are fine. (In Vic. anyway.)
I have questioned it myself I must admit, IMHO I think that the high-brightness LEDs on windscreen washers are dazzling, I also think the rear red fog lights on Excels are dazzling and they should all be recalled and defected! But they're not...
We have been trying to get info on legislation for the various states, it hasn't been easy. I spent an hour trying to find the document I quoted from on the web, to no avail. Ended up typing it all.
From the layout of the document it came from the vicpolice.vic.gov.au site. We have been looking for a statement like this for a while, and finally received this last month. Haven't seen anything from any other states though.....
https://www.sau.com.au/forums/topic/27498-installing-neons/#findComment-584135
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
