Just dont do it.
I would expect:
Custom Dump Pipes
Custom Oil Feed Lines
Custom Oil Return Lines
Custom Water Lines
Custom Turbo Intakes
Custom Compressor Outlets
Custom Intercooler Piping
Pretty much custom everything all just to save a few hundred....just by bolt ons.
for starters they are not really an upgrade and the flanges are different. complete waste of time and money. there are plenty of actual bolt on turbo options for GTRs in both single or twin set-ups to suit every possible power/response/budget compromise you can think of. use one of them.
Wrong style of turbine and compressor housings , RB26 turbos are an engine specific T28/GT28 so not the same as a generic T28 or GT28 turbo housing wise . Something had to be done to get two parallel turbos close in to the head on an RB26 and somehow leave space for oil/water/air/exhaust in and out .
A .
i would think the t28 would make a difference,i have a gtr t28 here and a t28 s15 turbo, and the gtr is far to small even the intake ports for the exhaust are waaaaaaay to small, i can barely fit two fingers in there. lol. but yeah i would assume the s15 t28 would be a bitch to modify to fit, far better options are out there, as the flanges are different and oil and coolants as well.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
