Just bought R33 GTS-T Coupe
Had roadworthiness done but since buying car engine occasionally stalls in situations where there is a lot of change in speed such as in traffic jams (which is an awesome experience).
Mechanic reckons the fuel pressure regulator is stuffed but that replacing it will cost around $300 because the new part can only be sourced from Japan.
Looking for anyone with a new or second hand fuel pressure regulator in decent condition as my hip pocket can't handle importing.
Cheers.
https://www.sau.com.au/forums/topic/275001-engine-stall-in-traffic-jams/
Mate, I doubt it's your FPR.
Check simple things first:
1) Clean AFM with carby cleaner.
2) Check that the AFM connectors in the little black box are welded correctly
Yeah try the afm. But my money's on your IAC valve, its either dirty or the unit itself might b screwed.
I had this same problem wen i bought my car. doubt its your fpr.
hope this helps
Thanks for the feedback Turbz RB-25, Benzino33, RICCA, axe s, A31Drifter and TWINS33.
Im heaps green with skylines so its good to get some info from ppl with more experience. The mechanic that looked at my car reckoned it was the fpr because they usually hold pressure with the ignition off and mine doesn't.
So I'll try cleaning the AFM, check the connectors, check the IAC valve and the BOV. All this stuff is simple to do if I follow the Skyline manual right?
If I find its none of these then I might hit you up for that fpr axe s.
Cheers again for the help,
-FIXER5.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
    • I use FCC car launcher. It has an option for different backgrounds, so instead of turning the screen off you can swipe 'up' to a black screen with no background/icons. (mine has the time on it only). It's kinda nice. Also lets you use gestures to say swipe to go to next song, etc.
