only right hand door and front gaurds damages in crash
hay guys im buying a 33 of my mate cause he crashed it so chucking everything up for sale!!
whole cars is there. Its white
only things not forsale are right hard door and front right gaurd as were damaged in carsh.
im also keeping all the brakes cause im using then for 5 stud convo.
Also keepin the motor and gearbox (RB25DET) unless someone offers me somthing i cant say no to.
Everything else up.
left hand door. $150
left hard gaurds. $150
front bar. $100
rear bar. $100
boot. $150
bonnet. $150
spoiler $50
left hand mirror $50
rear lights. $150
front lights. $100
indercators. $20
genuine skyline floor matts. $ offers
passenger seat. $200
rear seats. $150
rear window. $100
left side windows. $50
dash. $200
left side door trim $50
centre consol $50
rear seat belts $50 buks
passenger seat belt $20
rear veiw mirror $20
front hubs. $200
all the front arms. $200
all rear arms. $200
stock 33 sussy. $500
exhaust from after dump pipe $ 600
got a full set of 17 inch meshys, muti 4 and 5 stud (will check size and offset when pick up car)
front tires like new rears bout 50%
have some gutter rash and one rim has black mark from crash (will prob clean myself)
$600
whole rear end.
LSD diff, ect ect $900
all i can think off atm, if you want somthing just ask away
in adelaide
would rather pick up.
pm or 0411592938
Edited by scottmiller92
https://www.sau.com.au/forums/topic/275043-stripping-r33/
dibs on headlights if there good condish, please post up pics of the headlights mate.
cheers Jack
yeah mate there pretty good, no crack ect ect.
just a lil faided thts all. get a pic on friday night when i pick it up :)
https://www.sau.com.au/forums/topic/275043-stripping-r33/#findComment-4660762
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
