only right hand door and front gaurds damages in crash
hay guys im buying a 33 of my mate cause he crashed it so chucking everything up for sale!!
whole cars is there. Its white
only things not forsale are right hard door and front right gaurd as were damaged in carsh.
im also keeping all the brakes cause im using then for 5 stud convo.
Also keepin the motor and gearbox (RB25DET) unless someone offers me somthing i cant say no to.
Everything else up.
left hand door. $150
left hard gaurds. $150
front bar. $100
rear bar. $100
boot. $150
bonnet. $150
spoiler $50
left hand mirror $50
rear lights. $150
front lights. $100
indercators. $20
genuine skyline floor matts. $ offers
passenger seat. $200
rear seats. $150
rear window. $100
left side windows. $50
dash. $200
left side door trim $50
centre consol $50
rear seat belts $50 buks
passenger seat belt $20
rear veiw mirror $20
front hubs. $200
all the front arms. $200
all rear arms. $200
stock 33 sussy. $500
exhaust from after dump pipe $ 600
got a full set of 17 inch meshys, muti 4 and 5 stud (will check size and offset when pick up car)
front tires like new rears bout 50%
have some gutter rash and one rim has black mark from crash (will prob clean myself)
$600
whole rear end.
LSD diff, ect ect $900
all i can think off atm, if you want somthing just ask away
in adelaide
would rather pick up.
pm or 0411592938
Edited by scottmiller92
https://www.sau.com.au/forums/topic/275043-stripping-r33/
dibs on headlights if there good condish, please post up pics of the headlights mate.
cheers Jack
yeah mate there pretty good, no crack ect ect.
just a lil faided thts all. get a pic on friday night when i pick it up :)
https://www.sau.com.au/forums/topic/275043-stripping-r33/#findComment-4660762
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
