Ppg Straight Cut Dog Box And New Transfer Case
This is a fully optioned PPG dogbox it has billet shafts, selector forks and sandwich plate. Comes with NPC twin plate clutch and genuine C's short shifter...these items are 3 meetings old and are in perfect order.
over $15K to set-up
$10 000 firm
Edited by DiRTgarage
For those people PM'ing wanting prices on various bits....please understand this...
The clutch and box runs a larger spline input shaft....you will need both the gearbox and clutch to make it work.
If you only buy the gearbox you will have to get your own clutch rebuilt/modified to suit the shaft...alternatively the clutch will only suit the larger spline PPG input shaft so is no good for a car running a Nissan box. Save yourself the headache sorting various bits to make it work i.e. correct height bearing carrier etc.
This is a cheap way to this set-up and not even factoring in the price of the transfer case or the base gearbox used to modify is a 33% saving off what it would cost to build. PPG no longer produce the billet sandwich plate and when they did that item alone was $1100! In my opinion the sandwich plate is what makes this box bullet proof as it reduces a lot of flex and stress.
  • 9 months later...
back up for grabs guys...just had full service by Currumbin Diffs in QLD and now shifts like butter. It has had two street meets since service and the guys who did the overhaul obviously know what they are doing as its incredibly slick.
Our custom 4130 billet shifter with 4 load sensors and top of the line ignition cut controller interface (same as what HRT uses) is also available as an add on for an additional $1200. This allows for fully programmable clutchless full throttle shifts.
Edited by Swiper the Fox
  • 3 weeks later...
 Share
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
