OK ,, UPDATE
I bought a cheap ODB cable off ebay as a speculator that it may work on the M35 as I do not know of any other ones that work. FAIL :D
I have now learnt that many Nissans that are JDM only have a very odd (read unique) ODB protocol. The Protocol it uses does not work logically which is why the software seems to have a problem. There are some Very Expensive options that can be purchased that will work on our car but we are talking around $500 and that is too rich for me.
There may be another option on the horizon that may help. I am waiting to see a prototype but it will be a few months before it is ready but the cost is reasonable.
I will keep you posted.
Cheers
Andy
UPDATE on mine.....
I went to my mates workshop..
he just updated his OBDII scan tools with newer car...
and i got him to reset the ecu ...
now my car idle like a dream at 650 spot on as it was ideling at 750-950 before...
i expect i should save a bit more fuel now!!
Real Happy today!!!
p.s. Andy. do u want his details maybe worth go and see him? he is located near Arncliff...
If you can let me where he is and a contact number that would be great.
Cheers
Andy
i found some OBDII software on the net, haven't tryed it because i dont have an OBDII car to try it on. i think its called Scantech or something like that, might be worth a try.
Edited by QWK32
thanks cam. ill try to dig my cable out and have a test tonight.
now, gotta find a USB to serial converter that works :)
i've been using a belkin serial convertor with a couple of the different consult software for a while now with out a problem. this is also on a couple different laptops, one's even a mac.
is the M35 OBD port the same as older nissans?
Edited by QWK32
its a generic one that i bought from someone from silvia nsw. he was making them himself and worked with my S15s. i wonder if it will work with the M35?
Wouldn't that be OBD-I though?
M35's are OBD-II
Josh,
If you don't mind could you give me the name or a link for the Mac software you used for consulting?
I'm on a MacBook Pro and had given up any chance of using for consult because everything was PC based.
The M35 is OBDII, is that going to cause issues?
M35's are OBD-II
anyone know if the connection is the same between the two. i have this funny feeling its only the protocol that is different (I or II) but the plug/interface is the same.......
OBD 2 is different to OBD, but that is only the start of it. There are then about 5 protocols (that I have worked out so far) that are used by different companies. Nissan are using KWP2000. I am told that this would not normally be a problem but Nissan have used some different logic in the process. Not quite sure how this works out in the real world but it has meant so far that some of the ones that by all logic should work have not.
These include:
http://blazt.biz/index.php (works on the V35)
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...RK%3AMEWAX%3AIT (did not work)
I have read al lot about the pins and what they all mean. This site may help make sens of it all.
http://www.scantool.net/support/index.php?...p;kbarticleid=3 (where are type A)
Our pins are: 1, 2, 3, 4, 5, 6, 8, 9, 12, 13, 16.
Hope this helps you guys work out more information.
If any one knows of any reasonable priced system that will work with the M35, please let me know.
Cheers
Andy
Josh,
its only a trial and then you have to register it, its the only Mac ported software i've found ConSultan
i also have a macbook pro, and i've only just started using ConSultan (im still on the trial period), but i also run a Parallels XP Virtual Machine and use all the windows based consult software like ECUTalk without a problem.
Bugger
"ConSultan is a Mac OS X program designed to communicate with the Consult port of your pre-1999 Nissan vehicle"
Mine is a 2001 model, oh well :thumbsup:
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
