Did you perform the reset procedure after cleaning it? My idle is a bit high, but it could be my ECU forcing that
Ulikely that it is the Impul ECU. My idle is bang on 650rpm.
When you do the reset procedure if it does not set between 600-700rpm it will not be memorized by the ECU and will climb over the next days/hours.
Just gave the procedure a go; idles on exactly 650 now (with the occasional +/- 20rpm) :thumbsup:
