Bugger
"ConSultan is a Mac OS X program designed to communicate with the Consult port of your pre-1999 Nissan vehicle"
Mine is a 2001 model, oh well :D
the only other thing you could try if you were keen on getting something running on you mac is use Parallels or VMware Fusion and run the windows consult software from your mac, its the easiest way apart from a complete native install of windows from bootcamp.
For the M35 guys who have not seen my posts in the V35 section.
I have found yesterday that the PCV on my car may be faulty.
It is not meant to be be leaking any air back into the manifold at idle but mine is.
It seems that my earlier stalling problem and now my high idle may all be related to this faulty part. I have ordered the new part and will also remove the current one and try to clean it.
I have attached a photo of the location along with an the technical information for the G35.
Cheers
Andy
Hi,
My M35 has been having idle problems for about the last 3-4 months.
I've narrowed it down to a fairly specific case - and I can verify this almost every time now.
It generally idles at 500rpm - has done since I got the car (oct 2008). Occasionally it will idle at 650rpm as it should, but I find this is mostly when its cold. Once it warms up, the idle revs drop to 500rpm.
It actually idles very smooth at 500rpm most of the time, so I haven't worried too much about it.
However, if I rev it just a tiny bit then take my foot off the accelerator again straight away, it will splutter before coming back up to 500rpm. Sometimes it doesn't recover and just stalls at this point.
If I'm rolling along slowly and release the accelerator, and then turn the steering wheel, the extra load from the steering is usually enough to stall it. However it is not an issue with steering, because it will still splutter even when its stopped and/or when the steering is at the centre (ie. straight ahead).
Some other things about it:
* ONLY happens when the engine is warm. Seems more likely when the weather is hot too.
* Only happens when idling or revving below say 600rpm. When travelling anywhere over say 10-20km/h or with any pressure on the accelerator - it wont stall.
To my way of thinking it must be airflow related - ie. the engine being starved of air at the moment the throttle closes - (or almost closes?).
I've performed the Accelerator position learning, throttle closed position learning, and idle air volume learning and all seem ok except for the idle air volume one. Either it stalls straight away, or otherwise it pretends nothing is wrong but still insists on idling at 500rpm. Doesn't seem to be "learning" anything. very stubborn!!
No ecu fault codes come up when I check this either - its always 0000. Any ideas? Anything I can check?
  • 1 year later...
Idle Air Volume Learning
Description:
Idle Air Volume Learning is an operation to learn the idle air volume that keeps each engine within the specific range. It must be performed each time electric throttle control actuator or ECM is replaced, or if idle speed or ignition timing is out of specification.
Preparation:
Before performing Idle Air Volume Learning, make sure that all of the following conditions are satisfied. Learning will be cancelled if any of the following conditions are missed for even a moment.
- Battery voltage: More than 12.9V (At idle)
- Engine coolant temperature: 70 - 100 Degrees C (158 – 212 Degrees F)
- PNP switch: ON (Park/Neutral Position Safety Switch - AT only, MT fully depress clutch)
- Electric load switch: OFF (Air conditioner, rear window defogger, headlamps. Note: on vehicles equipped with daytime light systems, if the parking brake is applied before the engine is started, the headlamps will not be illuminated.)
- Steering wheel: Neutral (Straight-ahead position)
- Vehicle speed: Stopped
- Transmission: Warmed-up (For A/T models, drive vehicle for 10 minutes.)
Operation Procedure:
1. Perform "Accelerator Pedal Released Position Learning"
2. Perform "Throttle Valve Closed Position Learning"
3. Start engine and warm it up to normal operating temperature. - (EDIT: THIS IS IMPORTANT - i've tried it when the car is cold and it will likely adjust the idle incorrectly so that when the car warms up it will idle too low).
4. Check that all items listed under the topic PREPARATION (previously mentioned) are in good order.
5. Turn ignition switch OFF and wait at least 10 seconds.
6. Confirm that accelerator pedal is fully released, turn ignition switch ON and wait 3 seconds.
7. Repeat the following procedure quickly five times within 5 seconds:
7a. Fully depress the accelerator pedal.
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the MIL turned ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure that idle speed and ignition timing are within the specifications:
Idle speed A/T: 650rpm, + or - 50 rpm (in P or N position)
Idle speed M/T: 650rpm, + or - 50 rpm (in N position)
Ignition timing A/T: 15 Degrees BTDC, + or – 5 Degrees BTDC (in P or N position)
Ignition timing M/T: 15 Degrees BTDC, + or – 5 Degrees BTDC (in N position)
13. If idle speed and ignition timing are not within the specification, Idle Air Volume Learning will not be carried out successfully. If idle speed and ignition timing are within the specification and Idle Air Volume Learning cannot be performed successfully, find the cause of the incident by referring to the following Diagnostic Procedure:
1. Check that throttle valve is fully closed.
2. Check PCV valve operation.
3. Check that downstream of throttle valve is free from air leakage.
4. When the above three items check out OK, engine component parts and their installation condition are questionable.
5. If any of the following conditions occur after the engine has started, eliminate the cause of the incident and perform Idle Air Volume Learning all over again:
- Engine stalls.
- Erroneous idle.
Guys - I think I have the same issue. Scotty fitted the suction pipe and resetted the ECU. Drove him fine, and as I came around the corner from my home I gave it a squirt, and as I slowe down to park the engine stalled. Lucky I was right outside my home and I was able to part to the side of the road and not stuck on some intersection!
Scott showed me the procedures here and I tried them - but I can't completed it because at step 10, my engine stalls as soon as I start it. I can keep it running if I rev if but if I don't it'll just stall...
Any pointers? Would love to sort this out without having ti drag Scotty all the way out tomorrow!
In my case it was the throttle getting stuck closed. Because the M35 is drive-by-wire, the ecu keeps the throttle open just enough at idle to regulate the right amount of air coming in...but in my case it was a bit sticky around the inside of the throttle body and it would get stuck in the closed position just long enough for it to stall.
Might be worth checking that your throttle body is clean - you need to check the engine side (ie. not the intake side) - it may look clean when you take the rubber hose off but if you wiggle it you'll see black all the way around the outside etc...
After this is done, then you may need to do the idle-air-learning thingy that was posted here. you'll know if you need to do it because your car will be idling higher... It should sit dead on 650rpm at idle if its running right...that's what mine did after I fixed this. It made such a huge difference and I was glad that I found it before shelling out hundreds to a mechanic...
I will bring some tools around tomorrow night after work buddy, rip the throttle body off and clean it, check the cooler pipes for leaks etc. Pity it didnt do it while you were at my place. lol.
This is the first i've seen of this thread, and I CBF reading through the entire 4 pages....
I had a similar problem with my x-trail. It happened as soon as I messed with the engine management.
Have you modified your car at all OP?
LOL tell me about it...damn cars!!
Just bolt on mods.
Dump pipe/exhaust
Intercooler
And today as per my post, the suction pipe.
blank im pretty sure, do you have an engine light up?
I'de say do a quick check on all the silicone joiners, including the ones to you FMIC.
mine were constantly blowing off the HDI Clamps are shit as the band is too broad.
OK I seemed to be getting this fault code:
10 x slow blinks, the 10 x fast, 10 x fast and 10 x fast...
Any idea?
Glad you got it sorted, but for your reference 10 blinks = "0"
So there was no fault code displayed (0000)
Dirty throttle plate was the culprit, sticky black gunk was blocking the gap. A little WD40 on a rag and now there is a great 650 rpm warble from the exhaust. :thumbsup:
Did you perform the reset procedure after cleaning it? My idle is a bit high, but it could be my ECU forcing that
heh, exactly the same problem I had then. Glad its all sorted. :)
    • Looks like they've been through a few versions of the kit; that is not the one I had trouble with (it had the level sender attached to baffles on the floor, the one you linked the level sender is hung from the hat). One obvious point about that kit is it has no baffles at all, not even the factory setup (although it looks like you can retain the factory setup if you want).  Not sure if that will be an issue or not, the good news is it looks like you can get the pump nice and low in the tank, but that doesn't help if the fuel is all sloshing to one side of a wide flat tank
    • One more question if you don't mind. Is the first kit you tried the same one as they currently sell as their fuel-pump-hanger kit? https://frenchysperformancegarage.com/collections/fuel-system-kits/products/fpg-bnr32-fuel-pump-hanger-kit-single-fits-stagea-c34-nissan-skyline-gt-r-r32-fpg-087?variant=42131478315186 Because according to their video the low fuel warning thing can be taken from the OEM hanger and attached to their new hanger. Just wondering whether this is the kit you weren't happy with, or whether it's a different revision. Thanks again!
    • That's the thing....the basics of fuel and ignition are deceptively simple.....getting it to behave like factory in all conditions after airflow mods is way more complex. Newer cars like the V37 are all about modifying the standard ECU which is about a billion times more complex than they were 20 years ago, with a bunch of parameters affecting others
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 🤣
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
