I've already put a wanted to buy up for rear brembo's, i think the plan will be put them on with the entire rear cradle along with front ones and try and find wheels after the fact, because the 32gtr 16inch one will be useless.
The 450 would be lighter then the previous motor yeah? It's an alloy block right?
Either way, the GTR is a more nose heavy car then a 180 or GTS-t ever will be. It's got the extra diff, transfer case and assorted bits up front...
it's actually about 20kg heavier than the CA18DET that was in it.
but a standard 180 is pretty limited on Tyre width up front because of the the narrow guards and factory offset. I'm pretty much limited to 8 inch wide unless i pump the front fenders.
which is why S13's have so many widebody front fenders available for them. I can fit 10inch wide rims on the back the moment after extensively rolling the rear guards with a 2 inch metal pole.
It's true test will come at the texi. we'll see if it turns then.....all else fails, clutch kick!
It's still going to have a better weight bias then a GTR though...
Tyre limitations is another thing though, but I'd definitely be putting rear brembos on, other wise you're WAYYYY over braking the front compared to the rear.
gotta find rear brembo's first. problem is that i hate the fibreglass wide guards everyone has out for 180sx's, I used to have a set on it and I hated them. I'll get a second pair of fenders and weld in another inch of metal at the inside edge, that way I'll still have stock looking guards.
clutch is buggered, sticks on the floor and is either on or off pedal feels like it binding. pretty much impossible to drive. hope the actually clutch face and pressure plate are fine other wise I've paid $2500 for a clutch that only lasted two months. VERY PISSED OFF!:angry:
still have find out what caused it, hopefully the custom bell housing was aligned properly.
Bellhousing isn't aligned I'm guessing. Probably needs a lazer alignment down the center.
Not my fault!! :ninja: Good job in removing the box yourself too!!! I didn't have to do it for a change!! :laugh:
it's laser, s not z as in Light Amplified Stimulated Emission of Radiation. but yeah my guess is needs alignment, and hopefully the clutch is still OK
looks like the gearbox is out of alignment, the fingers on the pressure plate have an ellipse shaped wear mark. the bearing is the same and the snout has wear markings on the top of it that has resulted in a slight lip which explains the change in clutch feel lately as the lip got worse so did the clutch. this tells me that the gearbox is positioned slightly too high compared to the engine. MRC are going to swap my bell housing and adapter plate for new ones that have been made at a different engineering firm. the clutch itself looks alright. not as bad as I originally thought.
  • 3 weeks later...
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
    • I've been quietly following this thread for ages, but this one got me. Since my ADHD diagnosis (and associated learnings and prescription) I'm way less inclined to wade into forum yarns when there are better things to do with my time, as half the time I'd end up in some kind of forum debate even if that wasn't my intention. I've not lost the ADHD "superpowers", just am a lot better at directing my hyperfocus into slightly more constructive things, but haven't stopped quietly lurking in here in my spare time.
    • Stripped the tank down and gave it a good scrub. It came up really good! Not sure if I'll just put it back in like that or give it a blackening treatment (such as Bowdens The Black Box). That might give it a matte look so might just run it as is.
    • @MBS206 Ha ha, yeah ADHD is a daily battle to not get drawn in to doing things you want to do that you know you shouldn't do!  Every single time I walk into my shed I end up doing something I started the day having zero intention of doing! I keep mentioning the 1 step forward, 3 steps back scenario and I'm tipping people that are blessed with ADHD (yes, blessed) are the worst at that!
    • We import a lot of cars from Japan. I'd say that approximately 20% of our traffic is imported JDM cars (mainly consumer cars like the Mazda Demio, Toyota Yaris, Honda Fit, Suzuki Swift, etc.). We also import a lot from the UK, but this has decreased after Brexit. Apart from the consumer vehicles, two of the larger, well-known dealerships frequently import iconic '80s/'90s JDM cars. I haven't heard of anyone importing from Australia, and they are not advertised (unlike Japanese ones), despite a lot of Maltese migrating to Australia in the '50s and '60s.
