been going through john unqiue autosports. vh45de's are mental does 226rwkw with only an aftermarket airfilter and exhaust, and allows me to do a 13.1 sec 1/4 mile. and even then I have to launch at only 1500 rpm or I get massive axle hopping.
  • 3 weeks later...
  • 8 months later...
update...
since my relocation to Queensland we (by we I mean GTRsean) achieved quite a bit:
R34 gtr Brembo brakes front and back which needed R33 gst-t hand brake cables
R32 Diff and axles
R34 grt wheels
Modified a nismo power brace to clear the VH45
and apparently 2nd place in the member championship thanks heaps eric, was very unexpected.
yeah it's different, the old one was a standard viscous 4.11 hooked really differently, it's very immediate now. considering i used to drive it around with a tomei t-trax 2-way, but engineer wouldn't go near it with that diff still in it. lol forgot what real diffs feel like.
the wheels didn't fit a few years ago but since the tein super streets have gone in they clear the strut.
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
    • Do you plan on using 98 or e85?
    • This should be pretty easy. 200rwkW is just about the max power out of an RB25 stock turbo. So, 12ish psi on a 2.5L. That boost limited mainly by the prospect of seeing the turbine in the cat after the smoke show. A steel wheeled equivalent would likely happily do ~220rwkW at something like 17 psi, where it would probably be bumping into the usual limits of such a sized turbo. These things have like a .48 rear. You will not need the 0.86 rear. The 0.64 will be fine. In fact, if you were looking at various mid-200rwkW options for RBs, most of them would be in a 0.64 rear. So, I think you will definitely want to be no bigger than that for a same sized but probably even more efficient (at making power) modern engine.
